Odd Sound After Turning Off SS
Old Mar 15, 2012 | 11:38 PM
RBodeman's Avatar
About 6 to 7 seconds after turning off my SS I hear an odd sound of something dropping in the engine. It sounds like a plastic float. Happens every single time.
Any ideas of what that is?
Old Mar 16, 2012 | 12:12 AM
Normal. But I can't remember what it is. Someone will chime in with the answer.
Old Mar 16, 2012 | 12:34 AM
Could it be the blend door in the dash flopping closed once the vacuum bleeds off?
Old Mar 16, 2012 | 12:35 AM
IgottaWoody's Avatar
Normal....sounds like a metal ball dropping....probably a valve or maybe a check valve
Old Mar 16, 2012 | 12:49 AM
jmm121783's Avatar
To me it sounds like a clicking coming from the motor. Maybe it has something to do with the high pressure fuel pump/direct injection?
Old Mar 16, 2012 | 06:53 AM
That noise is a different one than the OP is asking about. His noise is the single,light thump,or bump. It is an SS only noise. Turbo related. I think something vaccumm related. BOV maybe?
Old Mar 16, 2012 | 07:43 AM
RobSSTurbo's Avatar
It's the TB closing after the power gets cut to it. The reason behind that is to keep the carbon build up off the blade.
Old Mar 16, 2012 | 07:56 AM
Thanks Rob!
Old Mar 16, 2012 | 07:58 AM
RobSSTurbo's Avatar
Your welcome.
Old Mar 16, 2012 | 08:11 AM
Cool, that makes sense, thanks Rob!
