P0017-p0090-p0341-p0128
Old Oct 22, 2018 | 02:27 PM
Lawrence Graham's Avatar
Hi guys . Sorry if I am doing this wrong thread wise not very computer smart. However I have these codes on the mother in laws 2008 i believe HHR SS. What should I start with exactly. Hoping maybe a bad crankshaft sensor and not timing.
Old Oct 22, 2018 | 03:04 PM
Welcome.
"mother in laws 2008 i believe HHR SS"
1st thing would be to find out exactly what year and model you're talking about. Also, would be nice to know the mileage on the car.
Old Oct 22, 2018 | 03:13 PM
If it is an SS, then the chances of a bad timing chain are very high. As well as a bad t-stat, I bet P0128 has been around for a while and the AC doesn't work.
Requires professional diagnosing.
Old Oct 22, 2018 | 07:17 PM
Welcome to the site, please identify the code or codes, and engine size and year.
Old Oct 22, 2018 | 08:14 PM
He put the codes in the title. And thinks it is a 2008 SS, the fuel pressure circuit fault leads me to believe that.
Old Oct 26, 2018 | 11:40 AM
andyb's Avatar
p0017 - - exh. VVT solenoid failed - - super common on GM 4 cyl cars. - - very easy to replace - - the part is $50 - - on top of the valve cover on the passenger side - the exh. VVT solenoid is the one closest to the firewall.
p0128 - usually a bad thermostat
Old Oct 26, 2018 | 01:20 PM
You are confusing P0013. P0017 is a bad timing chain, it just shows up on the exhaust side first because of geometry.
Old Oct 26, 2018 | 01:33 PM
Ah yes put the codes up there, well , I’m going to suggest changing the timing chain and the balance shaft chain and the water pump and thermostat, don’t forget new Dexcool!
Then let’s see what codes pop up after that
P0017 indicates a stretched timing chain
https://www.obd-codes.com/p0017
HHRfred2008
May 1, 2017 02:47 PM
Smoke Wagon
"How To" Tutorial Library
148
Sep 6, 2016 11:29 AM
user 72098230
Jul 25, 2015 11:23 AM
Carnage SS09
Jun 10, 2013 12:37 PM
szczerbaty
Nov 19, 2012 10:58 AM
