pete @ pedders
Old May 17, 2012 | 04:14 PM
badflt's Avatar
Angry pete @ pedders
emailed him and told him i had a problem with the rear springs binding and making noise, he assured me he would take care of the problem,10 emails later and no response . has anyone had any of the same problems with them
Old May 17, 2012 | 08:46 PM
Rod Run's Avatar
I've met Pete personally, a couple of times and currently have Pedder's products on multiple vehicles. Never had any problems with Pedder's customer service.
Please explain how your springs are binding and exactly how you installed them? also, did you use the factory isolators and which end of the spring did you place at the top?
Old May 17, 2012 | 10:02 PM
Miltown SS's Avatar
I had problems with a Pedders right rear spring clunking noise. When Pete says he will take care of you he means it...give him a little time. I contacted Pete through the Pedders forum via PM. It took a while but he did resolve my problem and I am very happy and will be a future Pedders customer. After no luck with the spring noise at an authorized Pedders dealer, Pete sent me a set of xa coilovers in exchange for the springs...the guy is pure class in my book.
Old May 17, 2012 | 10:03 PM
badflt's Avatar
i went exactly as the forum said, i also sent pics to pete and he said they have had to install rubbers around the springs, i just wish he would repond back to my emails as he said he wanted me to be happy with his products. would like to know where to get the rubber
Old May 17, 2012 | 10:07 PM
badflt's Avatar
pedders
installed them as per the instructions on the forum, i also sent pics to pete, he replied that they have added rubber around some springs. Just would like a response to where i could get the rubber from
Old May 18, 2012 | 12:59 AM
moonsign's Avatar
I'm having a noise problem on the right rear, with my Pedders springs. How do I contact Pete? Would like to quieting this puppy down. "Moon"
Old May 18, 2012 | 11:31 AM
Rod Run's Avatar
If the noise bothers you guys that much, you can cut a properly sized fuel line or heater hose in half and lay it between the spring and the seat on the bottom coil
Old May 18, 2012 | 12:21 PM
badflt's Avatar
Smile pedders
pete just contacted me and he is going to take care of the problem. Thanks for all your responses
Old May 18, 2012 | 12:59 PM
ChevyMgr's Avatar
Nice!
Old May 18, 2012 | 02:44 PM
moonsign's Avatar
Question again: How do I get in contact with Pete@ Pedders? Got a coil bind problem with the SS on Pedders springs. "Moon"
