pete @ pedders
Old May 18, 2012 | 03:17 PM
chefhhr's Avatar
Originally Posted by moonsign
Question again: How do I get in contact with Pete@ Pedders? Got a coil bind problem with the SS on Pedders springs. "Moon"
Maybe you can use some duct tape and some pvc pipe to fix it
Seriously, if you spend $300+ on springs they should be right so I'm sure Pedders will take care of the problem. I have a little noise with my Canucks but it's not bad.
Old May 18, 2012 | 03:50 PM
Miltown SS's Avatar
You can try leaving a message for him at Pedders USA or do like I did and go to the Pedders USA forum, sign up and instant message him. He is a very busy guy so it might take him a while to reply, but he will.
Old May 21, 2012 | 09:16 AM
rallycobalt06's Avatar
well it's good to know that i'm not the only one with this issue. might have to contact this Pete @ Pedders too.
so what's the solution from Pedders for this? some of y'all have said he's taken care of you, but how so?
Old May 21, 2012 | 01:03 PM
foolmoon_design's Avatar
Since it drops the car about 1-1.5 inches, has anyone looked to see if the stop plates are still parallel to each other? This could be the issue... Makes me just want to take a torch to the stockers.(Old school--place blocks at desired end height and just heat the coils) Or cut a revolution out, and grind flat?
I heard the fix for this was rubber cups... what do you do when these wear out? metal/rubber/metal + lots of movement = metal on metal.
I know the stockers have a cork donut... dam things fall out every time I jack the car up, and they have not aged well. Now that our cars are hitting the half way point in their designed lifespan, I would guess, more and more tiresome little noises will appear. I'm just glad its not like the eighties 'Vette's, the ones with the exposed allen bolts everywhere. The dam interiors would just about fall apart whie going over a speed bump. You worried if it didn't make noise. 300ZX same way. It really sucked to have put loc-tite on all the easy stuff only to have something rattle loose behind it.
Old May 21, 2012 | 06:29 PM
EcotecRacer's Avatar
Pete at pedder
Pgb@ peddersUSA dot com
Deb
Ar@ same
Old May 25, 2012 | 09:30 PM
badflt's Avatar
Smile pedders
Originally Posted by EcotecRacer
Pete at pedder
Deb
Ar@ same
Thank you pete for taking care of this. You are a man of your wordthum
Old May 25, 2012 | 09:52 PM
Any pictures showing issues you had?
Old May 26, 2012 | 06:58 AM
Pete made things right. That's awesome... Now what exactly was the fix?
Old May 26, 2012 | 08:11 AM
badflt's Avatar
Smile pedders
my springs were coil binding and making loud clunks, he sent me a set of extreme coilovers . getting ready to install them
Old May 26, 2012 | 11:32 AM
Miltown SS's Avatar
Glad to hear Pete fixed your problem
