Poor Baby
Old Nov 12, 2008 | 06:56 PM
hhrcrafty's Avatar
I blew a tire after putting only 1500 miles on my car. The OEM Firestones were impossible to find back then, so I just replaced the tire with one of similar tread pattern and wear/traction grade.
Old Nov 12, 2008 | 07:13 PM
hyperv6's Avatar
Originally Posted by bartSS
true true the only reason i mentioned the Eagle RS-A is because i had them on an older supra that i owned and they were awesome. But i just looked and i might go for some other pilot series that will have better traction all around. I dont think ill take price into consideration when i get new ones i just want something good. It just sucks to shell out 200 for a tire when the old one only had 4000 miles on it. But i got plenty of time before ill be replacing all the tires.... at least the back ones cant say the same bout the fronts
Tires will get cheaper and if you know the guy mounting them you can avoid the speed rated tires that you really don't as you will probably never run at 120 plus for long periods of time.
Pilots are not what they used to be. You might be better off in a newer Eagle or I imports but the Toyo tires are as good or better than most. Even Bridgestones.
Pilots on the HHR are OE tires and most OE tires are cheap. MFG do not want to spend a lot of money on the tires so they take short cuts to save. Goodyear is dropping most OE tires as they make no money on them and the OE tires do things like wear out early and blow out.
Old Nov 13, 2008 | 08:31 AM
bartSS's Avatar
Thanks a lot hyperv6 ill definately look into it. I appreciate the feedback
Old Nov 14, 2008 | 12:46 PM
bartSS's Avatar
I got the michelin for $120 through a friend that works at NTB.. Cant beat that deal
Old Nov 14, 2008 | 03:53 PM
Tuanies's Avatar
Don't the tires have some kind of factory warranty with them from Michelin..
Old Nov 14, 2008 | 05:07 PM
hyperv6's Avatar
Good price.
They tires have a warranty if it was a MFG defect. Road hazzards are not considered unless you pay for the extra coverage on aftermarket tires.
Old Nov 16, 2008 | 05:03 AM
BowTieBob's Avatar
Don't be too depressed. I just had to shell out 1500.00 for one new wheel and tire for my Vette, after a pothole incident.
Old Mar 3, 2009 | 12:16 AM
08hhr's Avatar
mine blew out at 500 ish miles both passenger tires they just popped off the rim like over inflated blew out in back they were over inflated at dealer they didnt take responcibility i had to replace one wheel and two tires i said the hell with it and bought potenza's and a nice set of wheels. if anybody wants the orig firestones i will sell them cheap
Old Mar 3, 2009 | 06:43 AM
jerSSey HHR's Avatar
Using a different tire can completely change the way the car handles. That would be my biggest concern if not replacing with OE tires. That being said, if folks here have had success with different tires that are cheaper, I'm all for using them when I need to replace the OEs.
Old Mar 4, 2009 | 11:34 AM
RocketBuSS's Avatar
http://www.vulcantire.com/cgi-bin/tiresearch.cgi
F the Michelins dude. Go for the Falkens :) True, you will never be able to drive in even a dusting of snow again, but for the money you cant get better grip and handling performance. Check out the wear rating... 200. Money.
