Question about Engine sound.
Old Jan 29, 2016 | 11:13 AM
Could it be carbon knock?
Old Jan 29, 2016 | 11:57 AM
Stealth HHR's Avatar
I hadn't thought about that yet. I will check on it.
Old Jan 29, 2016 | 02:48 PM
I can already dismiss the Chain tensioner since I replaced everything timing related except the valve timing gears at the end of the cams
Did the tensioner release? Either by itself or by slapping it (the sure way).
Old Jan 29, 2016 | 05:22 PM
Yes I double checked it before putting things back together.
Old Jan 29, 2016 | 06:45 PM
Dbeluscak's Avatar
Just to clarify, you did replace all the guides? You did mention replacing all timing related components(-cam gears). The intake guide was broken on both of my HHR engines. I can't help it but think it sounds just like the wife's SS did. Removing the valve cover would be my first step. You can check visually for any unusual cam or timing chain wear.
Good luck with the troubleshooting. Keep us posted.
Old Feb 2, 2016 | 01:23 PM
Originally Posted by Dbeluscak
I tried with headphones as well. Sounds like a the timing rattle. But if you've eliminated that possibility I think Kersh might be on the right track. I have strapped my cellphone to the valve cover for engine troubleshooting. Not exactly a good idea, but I can't see under hood the while driving.
Do you have a stock downpipe? Didn't see one in your sig.
Completely stock exhaust.
I was hoping the video would pick it up. It sounds as though the valves are noisy until the pressure increases. Is it possible a cam gear could be going bad? since they are automatically adjustable I thought that might be a possibility.
Old Feb 2, 2016 | 01:28 PM
All guides were replaced and the motor sounds the same after as it did before the swap. I wondered if these motors were just noisy under low boost/low RPM situations.
GinaM
May 25, 2014 09:50 AM
teknolla
Apr 27, 2013 11:01 AM
menance
Dec 22, 2010 06:14 PM
ralphb
Jul 25, 2008 03:38 PM
giant96
Jul 14, 2006 06:23 PM
