Reconfigurable Performance Display
Old Oct 26, 2008 | 03:10 AM
  #51
norcalmike's Avatar
yeah I'll take the bin any day
Old Oct 26, 2008 | 05:12 AM
  #52
08BlkSS's Avatar
yeah same here......should of kept it on the pillar, much better location.....I use the heck out of my "dash box"
Old Oct 26, 2008 | 07:22 AM
  #53
NY HHR's Avatar
I don't like it!
Is this an option or does it come automatically with the SS package?
Old Oct 26, 2008 | 07:38 AM
  #54
hyperv6's Avatar
Originally Posted by hurst equipped
there is one reason why this is better than all of the aftermarket gauges. it has a warranty. the RPD is over 25 gauges in one. it is a:
boost
A/F ratio
cam phase angle
spark advance
spark knock
engine power
engine torque
speedometer
laterial G-force
left G-force
right G-force
maximum G-force
shift light
gear indicator
individual wheel tire pressures
Barometer
outside air temp
battery voltage
coolant temp
air inlet temp
fuel pressure
plus the following indicators:
stabilitrak, traction control, ESC, competition driving mode, and launch mode
Well my aftermarket one has:
1. INTAKE AIR- Intake Air Temperature - **
2. COOLANT TEMP- Engine Coolant Temperature **
3. TRANS TEMP 1- Transmission Temperature for automatic gas vehicles
4. RPM- engine Revolutions Per Minute **
5. MAF SENSOR LB/M- Mass Air Flow (lbs/min) **
6. MAF FREQUENCY- raw Mass Air Flow sensor output (frequency)
7. MAF FREQUENCY 2- raw MAF sensor output for the Cobalt SS and Redline
8. MAP SENSOR- Manifold Air Pressure (kPa) **
9. BOOST – Intake vacuum/boost displayed in inHg/PSI. Corrected by altitude entry or barometer**
9. THROTTLE POS. PCT- Throttle Position percentage (0-100%)
10. THROTTLE VOLTS- Throttle Position sensor output (0-5 volts)
11. MILES PER HOUR- Miles Per Hour **
12. KNOCK RETARD- Knock Retard (degrees) for most GM vehicles
13. KNOCK RETARD 2- used for KR value of ’94-’97 LT1’s and some 96/97 V8’s.
14. KNOCK RETARD 3- used for knock retard value of the Cobalt SS SC and Redline HHR SS
15. IGNITION ADVANCE- ignition timing advance
16. PULSE WIDTH- injector #1 pulse width (4&6 cylinder engines)
17. SHORT TRIM B1-short term fuel trim bank#1
18. SHORT TRIM B2-short term fuel trim bank#2
19. LONG TRIM B1-long term fuel trim bank#1
20. LONG TRIM B2-long term fuel trim bank#2
21. OXYGEN SENSOR B1-O2 bank 1 sensor in millivolts
22. OXYGEN SENSOR B2-O2 bank 2 sensor in millivolts
23. RUN TIME MINS- engine run time is tenths of seconds since last engine start **
24. BATTERY VOLTAGE- Alternator/battery output voltage **
25. IAC POSITION- Idle Air Control counts (position of Idle Air Control valve)
26. PULSE WIDTH B1-injector Pulse Width for bank 1 (8 cylinder engines)
28. ENGINE LOAD- calculated Engine Load (0-100%) **
29. ENGINE OIL PRESSURE (some 8 cylinder engines) **
30. INTAKE AIR 2 – Intake Air Temp. downstream of intercooler (some supercharged applications such as the Cobalt or HHR SS
SS, Ion Redline).
31. Miles Per Gallon 1- instantaneous fuel economy for gas vehicles
32. Miles Per Gallon 2- instantaneous fuel economy for diesel vehicles
33. HP 1- Calculated net horsepower for gasoline vehicles
34. Analog 1 – analog input #1.
35. Analog 2 – analog input #2
36. TOTAL MISFIRES- Total misfires of all cylinders. Resets every minute.
37. BAROMETRIC PRESSURE- limited support on standard GM vehicles,
38. Altitude
39. Shift light
40. performance recorder
41. Will read 0-60-1/8 and 1/4 mile times and speed
42. Will read trouble codes
43. Will clear trouble codes
44. Gear selector
And more features like Fan control and other adjustable settings on the engine.
I already have in my standard SS Info center and dash
boost
speedometer
gear indicator
outside air temp
coolant temp
stabilitrak,
traction control,
ESC,
launch mode
The only thing I really lack is the G meter and colorful display with my aftermarket Aeroforce scan meter. It really offers as much or more and I keep my storage.
It is easy to install in 5 min and has a warranty. It really the same thing as GM's just taken to the next level.
The Chevy one is nice but I like the one I bought better. Just my call.
Note my list of the Aeroforce meter is editied to remove most of the features that it offeres for the non Ecotech engine. I may have missed something or not added a feature somewhere.
Old Oct 26, 2008 | 09:51 AM
  #55
hurst equipped's Avatar
yeah, the RPD is for performance oriented people, not packrats.
Old Oct 26, 2008 | 10:05 AM
  #56
Owebo's Avatar
Naa, it is just really ugly.....
Old Oct 26, 2008 | 11:14 AM
  #57
tsaints1115's Avatar
boost
A/F ratio
cam phase angle
spark advance
spark knock
engine power
engine torque
speedometer
laterial G-force
left G-force
right G-force
maximum G-force
shift light
gear indicator
Barometer
outside air temp
battery voltage
coolant temp
air inlet temp
fuel pressure
The only good thing about it is the fact that Onstar will be activated when you rearend that semi-truck while your busy playing with this gameboy wannabee.
Old Mar 14, 2009 | 03:47 PM
  #58
Czechman's Avatar
Originally Posted by Arne73
uggh-
Looks like some tacked on accessory from the mid 70's.
Yup, here we go again. I bought a new '65 Chevelle SS and if you ordered the tachometer it went in the place where the clock was and the clock was mounted in a pod on top of the dashboard whether you wanted it or not. My father worked at the factory and even he couldn't stop the clock installation.
Some things never change.
Old Mar 14, 2009 | 04:37 PM
  #59
KinseySS's Avatar
This is a horrible spot for the display. As much as I want this. I don't want it there.
Is there a way to get this install in a vehicle that didn't have one (in a different spot of course) or will it not be compatible with the wiring?
Old Mar 14, 2009 | 11:29 PM
  #60
masterchief1112's Avatar
it looks stupid. i wouldnt buy that.
