Replaced stock boost gauge with the Aeroforce unit
Old Jun 30, 2008 | 09:33 AM
HPVOHHR's Avatar
Having a Canadian vehicle, with boost gauge units in cryptic metric units (kPa)... I was longing for a "regular" boost gauge.
Instead of ordering the factory imperial unit gauge, I decided to get one of the Aeroforce Interceptor units as some others here have.
Gauge fits well in the stock a-pillar location. The Aeroforce gauge housing is not as deep as the stock unit though, so the oem attachment/securing locations molded into the backside of the a-pillar garnish can't be used.
Fortunately, Aeroforce supplies a universal bracket of sorts... with a bit of jury-rigging, it works just fine in the stock location. There's no need to modify the a-pillar garnish in any way - you just need to modify the universal bracket a bit.
Mine (as pictured) has a silver bezel, silver gauge face and red lettering. This combo looks great with my red/black interior.
For those interested in ordering one of these, the p/n is CNx01 for the newer GM vehicles.
Works great!
http://aeroforcetech.com
Sorry about the glare in the photos... need to get some when it's a bit brighter out and won't need the flash.
Old Jun 30, 2008 | 06:42 PM
bluonyx's Avatar
Looks great, this is just what I've been looking for. I can display yhe boost and coolant temp at the same time.
Did you have to buy anything extra to install with it (wiring, sensors, etc)?
How hard was it to wire?
Thanks for the info!
Old Jun 30, 2008 | 07:37 PM
HPVOHHR's Avatar
No need to buy anything extra. The gauge comes with:
- the gauge itself
- a universal mounting bracket (which you will probably need to modify a bit)
- wire with OBDII connector (gauge connects to the diagnostic port)
Don't even need to run power/ground to the gauge... it's powered entirely from the diagnostic connector.
You need to run the wire UP to the gauge area, starting from the bottom by the diagnostic port... the OBDII plug is too big to fish DOWN. The wire fits nicely along the a-pillar/hinge pillar area, between the end of the instrument panel.
To make the fishing a bit easier, remove the plastic trim panel under the steering column... just two hex-head fasteners down at the bottom. Top portion of the trim panel snaps in place (just pull it away/out). Once that's removed, there's a plastic brace that also comes out easily... 4 hex-head fasteners. With these two items out of the way, fishing the wire is much easier.
I wrapped a couple of layers of electrical tape around the new gauge housing itself, since it was a bit loose in the stock cutout location in the a-pillar... one or two layers of tape helped to snug it up in the opening a little better.
Old Jun 30, 2008 | 08:22 PM
bluonyx's Avatar
Great, thanks! I'll be ordering one later this week. I think I'll do the red display on black with chrome bezel to match my red/black interior.
Old Jun 30, 2008 | 08:34 PM
Chevy SS's Avatar
Not a fan of the digital gauges, but it works. Nice purchase.
Old Jun 30, 2008 | 08:41 PM
TheBug's Avatar
I think this going on my shopping list.
Old Jun 30, 2008 | 09:15 PM
gcsd3742's Avatar
Only $260.00 kinda expensive dont you think?
Old Jun 30, 2008 | 09:32 PM
405HP_Z06's Avatar
Looks nice! I bet a black face would look nice also. How bright is the LCD at night? Overbearing?
Old Jul 1, 2008 | 07:44 AM
HPVOHHR's Avatar
Re: the brightness...
You can select from 3 different levels of brightness from the setup menu. It's also possible to invert the background and font/number colors as needed, for daytime or night viewing.
Yes, it is a bit expensive. Considering the number of parameters it can view though, and the fact that you can view and clear DTC codes, datalog etc... I think it's a fair price.
Old Jul 23, 2008 | 07:20 PM
gcsd3742's Avatar
Works great!
who did you actually order it from? I cant get no one at Aeroforces # or email
