Rotor Choices
Old Jul 21, 2011 | 06:45 AM
jonboyb's Avatar
Rotor Choices
I'm at 61k and have developed a light pedal vibration/steering wheel shudder under braking. Since my factory rotors went 60k without issues I'm hesitant to go aftermarket on the rotors and I'm considering just having mine turned. My father owns a NAPA so getting new rotors isn't an issue (not going through GM at $100 a pop).
Opinions on turning the factory rotors or getting dad to order me a set of NAPA premiums???
Old Jul 21, 2011 | 07:23 AM
solman98's Avatar
At 61K, might want to see if there is enough left on them for a turn. Might make your decision that much simplier.
Old Jul 21, 2011 | 11:18 PM
X 2, look before ya leap $$
Old Jul 22, 2011 | 08:40 AM
unique_w's Avatar
Rotors
Not a fan of turning rotors, your Dad should be able to obtain a very good trued rotor at a reasonable price. A thinner rotor may cause warping possibilities to increase.
Old Jul 22, 2011 | 09:21 AM
CarlsSS's Avatar
I did actually did have my OEM rotors turned at about 61K mi. when I first installed the ceramic pads up front. While I had no issues with warping and there was plenty of material for cleanup, the brakes had an annoying squeak as you came to a full stop.
That and the fact that they just started to look not as nearly as nice, with the rust and paint bubbling on them prompted my desicion to replace all 4 rotors with aftermarket drilled/slotted/plated rotors. The rears were always looking rusty and really had a grinding noise when the car had sat for a while. Got very tired of that for sure!
Very happy with my Ebay purchase so far, and no indication of any warpage or quality issues. Of course I'm very early in the life of these units and will track it closely... I figured they were pretty reasonable and worth giving it a shot. One slight differnce I noticed so far is the slots seem to give a very slight humming sound when lightly braking at between 30-35 mph. Not nearly as annoying as that squeak though!
Old Jul 22, 2011 | 09:47 AM
ATLsilverSS's Avatar
I have no vibration with mine....3rd set of pads at 90k
Old Jul 22, 2011 | 09:53 AM
Omnigear's Avatar
floating rotors from John Powell , it will outlast your car ^_^
Old Jul 22, 2011 | 10:41 AM
calgaryhhr's Avatar
I replaced my rotors with ATE PremiumOne rotors that I ordered through TireRack. Did this about two or three weeks ago and so far they are excellent rotors. I noticed that they were quite a bit heavier than stock and it seems like they are much higher quality. Time will tell though. I did have some shudder issues especially when braking downhill and a GM dealership machined the stock rotors at about 20,000km or so.
I'm expecting these rotors to last quite a while. My stock rotors went about 80,000km but were machined once.
Old Jul 23, 2011 | 09:36 AM
asanti's Avatar
Those are excellent rotors! I had them in my modified Neon and combined with OEM brake pads they were excellent in all types of weather. Unless the Tire Rack's added a new line, my only gripe is they don't offer rear rotors for the HHR SS.
Later
Allex
Old Jul 23, 2011 | 11:37 PM
OVRBOOST's Avatar
I went with a set of EBC dimpled and slotted when I bought a set of their ceramic pads. I don't really have any complaints, but I do have a little rotor shake after about 25,000 miles. If I had it to do again, I would probably buy the EBC pads, but just have the stock rotors turned and paint the veins and centers with some brake paint.
That is my 2 cents.
