RPO Code
Old Jan 20, 2021 | 02:27 AM
PITER88's Avatar
Post some pics from isle of hhr
Old Jan 20, 2021 | 06:29 PM
rorr's Avatar
Originally Posted by Oldblue
Then somebody installed those Brembo brakes after the factory build, some dealerships like Yenko, or Motion, might have installed them as a dealership add on , or a previous owner ordered a set from ZZP.
At least you can rest with the fact , your SS has them!
I noticed in the 2011 RPO list there was 3, 4, and 5 LT options, mine is a 2LT, I also noted the rear view camera option, but have never seen an HHR with that actually installed. My rear beauty bar has the provision to mount a small camera, but I guess they used a different rear view mirror.
I wanted the backup camera for my SS. I purchased the mirror from a Tahoe on eBay (found by searching the part number) and the camera too from eBay. I went to our local u-pick salvage yard and found 2 rear trim plates from 2011. One actually had the camera in it, so I snagged the rear hatch harness as well, all for $35. I made a custom harness after studying the GM wiring diagrams. I powered the camera from the mirror, picked up the reverse signal from the mirror, ran the video wires, a drain wire and installed it all. It works perfectly and didn't have to tear the whole car apart installing it, just the rear lift gate and headliner.
The only issue is the rear trim piece that mounts the camera and license plate lights has a mounting stud in a slightly different location, so I'm only mounted with 3 studs, which seems to suffice.
All in all, it works great and super happy to have a backup camera in my 09 SS!😁
Cheers,
Robert
Old Jan 20, 2021 | 07:34 PM
Yes the ‘11 has different mounting holes to clear the camera, I think the ‘10 was the same, but not the ‘06 thru ‘09.
Very cool you got it working, that’s awesome.
Old Jan 25, 2021 | 10:29 PM
prod's Avatar
The brembos are part of the G85 option, along with the LSD. Only available from the factory with the manual transmission.
Some 2008 SS had only the LSD, but there were very few.
gag
Apr 12, 2024 07:13 AM
ecpff
Aug 21, 2016 04:13 AM
douglas
Jan 21, 2014 03:55 PM
chefan
Feb 9, 2013 07:35 PM
gcsd3742
2.0L Performance Tech
Apr 30, 2009 08:14 AM
