shifter issues
Old Sep 12, 2013 | 08:40 AM
fasterbbc's Avatar
do you have the part number?
Old Sep 12, 2013 | 02:27 PM
pnad's Avatar
http://www.gmpartsdirect.com
shift cables 15939191 Manual transmission shift lever cable
$80.59
Old Sep 16, 2013 | 01:11 PM
fasterbbc's Avatar
Pulled my cables out last night the lateral cable is virtually froze. I have 1 of 2 assemblies on order.
Old Sep 23, 2013 | 10:33 AM
fasterbbc's Avatar
Problem Solved
Problem Solved,Problem Solved,Problem Solved,Problem Solved,Problem Solved,Problem Solved,Problem Solved,Problem Solved,Problem Solved
Sorry but I can't stand it when folks ask questions have a long lengthy thread and then never follow up with the solution. so here it is.
Symtom: 5 speed manual shifter very sluggish to move side to side, goes into gear (fore/aft) easily. As temp decreases below freezing stiffness only worsens to the point of stuck at 0degs.
Fix: Replaced the cable assembly and problem solved. Looking at the assembly the cable seal on the trans side is a little to be desired so I squired some additional lube down the tube. I also put some grease around the area to help shed the water as the cable points up possibly allowing water or condensation to settle at the seal point. I don't believe design is completely to blame. As 2 years ago the motor had to be replaced then within a week the clutch since the Dealer Boogered it up (imagine, See my other post on missfire and 11 time dealer attempts.) So between that area being messed with twice it mostlikely was bent then got some amount of corrision for its demise.
Problem: Dealers/GM is not stocking or making the assembly. I purchased the last 1 of 2 in the country.
Old Nov 11, 2019 | 08:20 AM
Dan Bellman's Avatar
So I know this is old but there is so little info on these 5 speeds. Did you replace the mech on top the trans. Mine is froze up and will not move side to side at all. Or the cables them selves. Thanks.
Old Nov 11, 2019 | 08:25 AM
Perhaps after six years he hasn’t logged in for a while, send him a PM , it might get your answer.
Old Nov 11, 2019 | 10:21 AM
He will probably get more of a response to his other posting on the same subject, as it has a little more info than what he is mentioning here.
Dan - tis much better to only post once on a subject/question, as posting the same thing in multiple spots just causes confusion and wasted time.
Old Nov 11, 2019 | 01:30 PM
Sorry posted as I found them this morning.
Old Nov 11, 2019 | 01:33 PM
So, I’ll close this one as it’s long in the tooth.
Old Nov 11, 2019 | 04:46 PM
The guy that couldn't find cables for his SS said GM sent him cables for a LS, Evidently they are in stock now.
LuckyLadySD
Jun 12, 2014 02:09 AM
bdlabaere27
Jul 10, 2013 01:13 AM
B.Diggity
Apr 27, 2012 03:26 PM
Doctuh
Mar 6, 2011 09:53 PM
