Shocking!
Old May 2, 2008 | 11:25 AM
ChevyMgr's Avatar
Originally Posted by dpoll995
where did you find that? ebay?
i live in houston texas. i never had this problem before in any other car i had here. but this is the first "new" car i bought since 98. all my others were used, perhaps they were already broken in... so far to remedy the charge i just grab part of the metal on the door before i get out, i just forget sometimes..lol.
Soon your humidity will be at it's typical 95% and you won't have to worry about the build up of static electricity until next winter.
Old May 2, 2008 | 12:28 PM
calgaryhhr's Avatar
You could try one of those grounding straps that Old Ray is pointed out or you could try grabbing the top of the open door or placing your hand on the roof before you try to slide out of the seat. That should transfer any current to the car instead of storing it inside the body.
Old May 2, 2008 | 01:05 PM
LT1GMC's Avatar
Originally Posted by dbfruth
I had a 98 neon that used to shock the piss out of me every time I got out of it. It drove me crazy. I found spraying the seat with Static Guard (the stuff for your clothes in the blue and orange can) would provide relief for a couple weeks. you can get it in the laundry section almost anywhere.
Yep, thats the answer, plus if you make it a habit to hold on to the door frame AS YOU ARE GETTING out, it will bleed off the static without any feeling it. I've not found it with the Perf seat I have, and I know its different in the area on the front, maybe thats a plus for it. since some don't like it for other reasons.
Old May 2, 2008 | 05:40 PM
MOTRV8D's Avatar
the only thing I might add is be real careful when filling up at the station.
some ppl (almost all of them women, BTW) have met with an untimely demise by getting in their car (let's say it's cold out) while filling up and then, when they get out of the car to shut off the pump they touch something, a spark flies and boom.
doubt this would happen to you but at least be aware of it. you might hop in your car if you forget something while filling up and the same thing could happen.
http://www.snopes.com/autos/hazards/static.asp
Old May 2, 2008 | 05:45 PM
ChevyMgr's Avatar
I read the same thing. My wife can make the hair on the back of my neck stand up just by giving me the "LOOK", just like static electricity. So I think women have this static build up already in them naturally.
Old May 2, 2008 | 09:04 PM
  #26
JayKWills's Avatar
okay, so now that we solved the car static, any suggestion as to how I can stop getting shocked as I push the shopping cart around Walmart every few seconds? That really drives me crazy!
Old May 2, 2008 | 11:07 PM
  #27
dpoll995's Avatar
umm.. dont drag your feet when you walk...
Old May 3, 2008 | 01:21 AM
  #28
mudd274's Avatar
dont shop wally world
and the women jokes
you guys are full of it
one more suggestion... try a dryer sheet or get some of the static remover spray and rub/spray it on the seat and see if that helps.
Old May 3, 2008 | 09:28 AM
  #29
Old Ray's Avatar
A temporary clip-on static strap for your shopping cart?
Old May 4, 2008 | 08:28 AM
  #30
PTGT 2 HHRSS's Avatar
I have the same problem. Does not happen every time. I'll try to pay more attention to what shoes I am wearing.
