Squeeeaaaky Brembos
After 2500 miles my Brembo brakes squeal like crazy, don't suppose anyone knows any secrets to quiet them? Might be hard to find replacements in the quiet type also, guess the noise and dust go with great stopping.
yeah what he said...It's a grease type paste you put on the back side of the pads....or aerosol or powder similar to these...
http://www.partsamerica.com/ProductL...?Category=3223
Mine don't make any noise. When I installed them, I applied the ant-squeal compound that was included with the factory pads in a very thin layer between pad backing plate and the stainless steel anti-squeal shim that clips on. I would suggest you pull out the pads (you don't need to remove the calipers, just tap the 2 pins out) so it is very quick), and check them. I am betting there was no compound applied on assembly.
