SS tire pressures
Old Jul 30, 2012 | 10:44 AM
  #31
Victory Red SS's Avatar
Originally Posted by Tominator
Stick with 32PSI...... recommended by GM and that pressure is for ANY tire!
Here we go again....
Unless you are driving over 125MPH...
So higher or lower if running over 125 Hit the limiter once at 132mph but have since changed it to 150.
Old Jul 31, 2012 | 12:18 AM
  #32
IgottaWoody's Avatar
Higher...dont want the tire to deform at those speeds
Old Jul 31, 2012 | 12:40 AM
  #33
Breadfan's Avatar
I run F-hawk Wide Oval at 32-34psi cold. They stay within 35-37psi if it gets hot during the day or the driving gets spirited.
Old Jul 31, 2012 | 05:58 AM
  #34
hyperv6's Avatar
Remember the faster and longer you run the more heat a tire with lower pressure will build.
This is mostly what happened in the Ford Explorer deal. The tires were not the best and people ran them lower than they should. Heat will make a tire fail.
This also is why we have no high speed rated white letters. The white rubber in the tire will get hot and fail at higher speeds. I think S rating is the highest white letter. They do have some letters now on some but they are like a press on like the NASCAR and Indy tires.
bthomas515
Tires & Wheels
13
Jun 11, 2011 08:03 PM
birdflames
Sep 29, 2009 11:48 PM
mo650chopper
7
Jan 13, 2009 07:46 AM
Seeburg220
Tires & Wheels
27
Sep 21, 2007 12:44 AM
cj krause
Tires & Wheels
Aug 3, 2006 06:46 PM
