Transformers Center caps?
Old Apr 3, 2010 | 07:59 AM
hyperv6's Avatar
Originally Posted by harleysshhr
That's true. But I think his first concern was that of center caps fitting on HHR wheels. When that seemed no go it appeared having Camaro rims working so that the transformer cap could fit. Yeah, there's no way the 20's or 21's could work as you said because of widths and offsets. But the 18's, now that's a different story. I could probably machine the correct opening on the HHR wheel to allow the transformer cap to snap in. As easy as that sounds, it's easier and less work to change the bolt pattern in the camaro wheels.
Most here like the SS RS wheels as they are most common seen snd liked. You know as well as I do if you make a statement here you had better narrow it down.
You had better also explain how to properly change bolt patterns on an HHR. You know that one is coming too.
Old Apr 3, 2010 | 04:58 PM
harleysshhr's Avatar
Gee, I hate to be a party crasher here, but the 2010 Camaro LS wheels will work with the change of the PCD. The 18" aluminum wheel has the correct offset and width.
I thought I did. I know what you mean, sometimes it takes a picture and then some even doubt that.
Old Apr 3, 2010 | 04:59 PM
hyperv6's Avatar
Old Apr 3, 2010 | 05:02 PM
Old Apr 5, 2010 | 01:54 PM
asanti's Avatar
Umm, what's PCD stand for??
Old Apr 5, 2010 | 02:02 PM
  #26
The Pitch Circle Diameter (PCD) is the diameter of the circle which passes through the center of all the studsCommonly referred to a bolt pattern.
Old Apr 5, 2010 | 05:19 PM
  #27
bunkie's Avatar
When you change the bolt patten on an alloy wheel do you use a threaded insert or a knurled press fit?
Old Apr 5, 2010 | 08:39 PM
  #28
Steel knurled press fit. Some OEM wheels come stock with the same steel seats. Mostly high end cars.
Old Apr 5, 2010 | 08:45 PM
  #29
BlackknighT's Avatar
Maybe I'm missing something here with going from center caps to rims, but my post from the first page of this thread has a link to a company touting the center caps for Cobalts... Wouldn't that be the same fit for the HHR center cap + the measurements are on that link.
Old Apr 5, 2010 | 09:10 PM
  #30
How this thread graduated from where it originated to where it is now was by the original poster reposting the below post.
Originally Posted by Tuanies
Because its much better looking with a factory part. Now I wonder if camaro wheels would fit
