TTR swaybar or not?
And a thicker one[like the OTTP "Hardcore" bar] makes a really big difference.
Makes even a SS corner like a slot car. I've put it to good use, and believe me it works real good. Most bars for the HHR are only one inch dia., the "Hardcore" bar is a inch and a quarter dia. With Pedders springs you don't need a front bar. The stock one works good enough. "Moon"
Moon, That discription of your about running around the track was pretty exciting sounds like the sway bar had some thing to do with the results is OTT over the top from Ibach ? Guess I'll have to get one wheres the best place ?
It's a definite improvement. I've the TTR bar and Pedders springs. I've taken tight 2 lane highway offramps fast enough to lap other 'sporty' cars getting off at the same time. All while not having much if any body roll and no tires squealing.
