TTR swaybar or not?
Old Dec 13, 2010 | 01:05 AM
Sleeper:
I think that make sense well do it that way THANK YOU
Old Dec 13, 2010 | 01:27 AM
mrsilent13's Avatar
Originally Posted by SS fan
Aaron at Turbo Tech Racing took good care of me might want to check his price on the pedders
yea i just seen that...price is better...thanks
Old Dec 14, 2010 | 10:07 PM
got it done today,with the TTR upper mount too,wish I knew it would raise the ride height,I would have ordered the springs at the same time maybe its just a SS thing seems like all of you who added the bar also added the springs.
Old Dec 14, 2010 | 11:26 PM
raise the ride height ? perhaps you jacked it up to install & the springs have not settled back down..
Mine didn't raise it..
Old Dec 15, 2010 | 07:37 AM
Sway ba should be installed with the cars weight on the ground, was yours installed on a lift? A sway bar shouldn't raise ride height at all........ Didn't on mine.
Old Dec 15, 2010 | 08:45 AM
  #26
Installed in the air then dropped on ground crawled under to tighten should I loosen bolts drive around block then tighten. Or loosen load some weight then tighten ?
Old Dec 15, 2010 | 10:40 AM
  #27
rallycobalt06's Avatar
go with PRS..... Powell Race Shop. you can purchase directly thru them or OTTP (Over The Top Performance).
1" Street Bar & rotated tranny mounts..... you DON'T need a solid engine mount.
Old Dec 15, 2010 | 11:27 AM
  #28
I have one and it works well would only suggest do the install before you fill the washer fluid HA
Old Dec 15, 2010 | 11:57 PM
  #29
When your ride is on the ground, loosen the 4 bolts, & then re-torque to specs.
This bar has no effect on ride height...
What happened imo (as I previously posted) your springs need bounced some to get settled back down, after you had the vehicle in the air..
Old Dec 16, 2010 | 12:17 AM
  #30
Yep, thats it loosened all of them threw in a few pounds re torqued them then ran over bout 50 speed bumps seems bout the same height now Thanks for all the help!!!
