Tubro Light flickering
It's to let you know that the flux capacitor is charging and ready for light speed!
Actually I haven't noticed anything like that but I have noticed that mine doesn't read correctly, dealer has a new one on order they are still diagnosing my problems.
Mine does not flicker, but I have a large capacitor across the battery for the sub, so that might have something to do with it. The actual function is another question though. Mine only works about 10% of the time, otherwise just stuck at 5 psi. The dealer has 2 on order, since there are two part numbers and we could not figure out the difference, and there are no part numbers on the guage. The pillar does have a part number label that looks like it woul dbe the whole assy, but it is for just the plastic.
Darn, with as erratic as these guages seem, maybe we ought to junk them for a conventional boost/vac guage operated mechanically, a tubing line run to the intake manifold. For all we know, Chevy is programming them to read higher boost than actual, just to make us feel faster. (could be done, something to think about, tuners could accomplish the same trickery) kinda like some tuners on Corvettes don't correct the tables that compute fuel economy when tuning for larger injectors. It can make you read higher economy readings than actual.
I notice a flicker in the boost gauge only when I first turn on the car. It flickers twice. I thought this was annoying, so I feel for those who have a constant flicker.
Good luck, hopefully the fixes go well.
purple people eater
Sep 17, 2016 01:07 PM
NxlKing2304
"How To" Tutorial Library
Apr 10, 2015 12:23 PM
itschaboykenny
Feb 17, 2008 12:01 AM
