TWM Short Throw Shifter
On the standard TWM HHR short shifter, the thread size is M12x1.25.
On the TWM HHR SS short shifter, the thread size is M10x1.25. We couldn't make it the same size as the standard HHR because the diameter of the shifter had to be smaller for the reverse lockout part.
Frank
TWM Performance
Frank
TWM Performance
I tried to put the pedal to the metal and pass someone today only to grind 3rd. MAN was I pissed. Every car I've owned for the past 17 years has been a stick and this one is the least fun to row through the gears. I've driven trucks that are smoother. Will this break in (I've 3400 miles on her) or will this shift kit fix the problem.
If you get a chance test drive a 08 Civic and let me know what you think...
JIm
JIm
For a shift boot you could check out redlinegoods.com. They make custom shift boots and seem to make them for virtually any car.
Thanks,
Kevin
TWM
