well...air filter cover removed and...
Old May 20, 2012 | 02:40 PM
xonelife1983x's Avatar
i hear the whoosh and turbo whistle a tad more but not enough to keep it off (muffler kinda blocks the sound). didnt have any codes kick up . did seem to effect the freshly cleaned k&n . took it down freeway. didnt seem to lose boost pressure either..
to each their own i guess. guess it depends on temps, barometric pressures, rain/sun, elevations, and tide levels hahaha... unfortunately my car gets massively dust covered at work daily, all week. so i'll be putting the cover back on in 20 minutes after i finish this burger
Old May 20, 2012 | 04:12 PM
Turbo Hearse's Avatar
I could hear mine a lot more when I took the cover off. Took it off the first day I bought it and it hasnt been back on since
Old May 20, 2012 | 04:25 PM
well now that its back on ... i will tell if its quieter or not.. but like i said work sucks with dust.. not only dust but limestone dust even at 90+mph unless u wash the car its stuck on . maybe once it comes back from body shop next week i'll take it back off. who knows :)
Old May 20, 2012 | 05:22 PM
bigjacksauto's Avatar
so are you guys simply just taking the lid off
wouldnt pulling in more heat slow it down or does the intercooler do that good of a job?
Old May 20, 2012 | 06:24 PM
badassbowtie's Avatar
the only difference ive noticed is the awesome sound....i think the intercooler pretty much does its job. and if you have an upgraded intercooler its probably even better. the turbo heats up the air to like 400-500 degrees (I think). so wether the intake temp is 30 or 100 degrees it doesnt really matter IMO
Old May 20, 2012 | 06:31 PM
redssna's Avatar
Cover on is your best bet. I'm sure it sounds awesome with it off but you want the most dense charge you can get feeding into the turbo. the colder the air is feeding the turbo the better off you are. its like making your car run on the hottest day every day without it.
Old May 20, 2012 | 06:36 PM
so... what we need to do is come up with a bigger aluminum tube from factory inlet in wheel well into the factory air cleaner housing? kinda like when you change the i.c tubes like the top one for example you go from a "crushed looking plastic circle" to a rounder tube of different material
Old May 20, 2012 | 08:33 PM
IgottaWoody's Avatar
Really depends on how u drive your car...if your sitting in traffic and the IC is heat soaking its not going to make any difference..cruising up and down the Blvd? No problem....trying to win street races ( money) or a night at the drags...sure, close it.If you want to go best bets, isolate the intake air to the hood ( scoop) and use the excess flow to draw heat away from the engine compartment...two birds etc etc
Most people with most types of driving will never notice the difference and for most people theres still plenty of power there,,everything else is bragging rights..
Old May 20, 2012 | 09:12 PM
ChevyGuySS's Avatar
IMO lid on or of, you will not notice a difference in any power, every other intake for this car basically is just a filter in the engine bay, 2 companies make CAI for this car, K&N and CIA. ive had my filter off for about 8 months and im not planning on putting it back on, i see no draw backs and it makes the car sound 232947562349876 times better
Old May 20, 2012 | 09:24 PM
Breadfan's Avatar
I'm sure you mean the lid. I'm doing basically the same thing. It might push the temps up 10*. I'm not drag racing, so no noticeable ill effect for me.
