What are the benefits of K+N intake?
Now, you can see why i dont care for 'em, because they dont care about me.
Just a couple things to note with KNN and any other oiled filter system. Most intake systems will make more noise like an old 4 barrel carb. Not an issue for most performance types but the accountant with a new Escalade ehh.
Also do not over oil the filter. Too many people over oil and take out the MAF sensor. They sometimes can be cleaned with carb cleaner but not always.
A little oil goes a long way. They note in their instructions not to over oil and they mean it. Most times in the performance after market the things that go wrong are self inflicted. The storys I could tell. LOL!
see the post above ^
If I were going to change filters, I would just use a K&N filter, and not bother with a new pipe.
The piping is under pressure most of the time, and any gains in H.P. & torgue is not worth the cost. Unless you bench flow the pipe, you can't tell any difference, other than looks, and I'll bet even flow testing there won't be any gains. They just want your $$, and if you bite, then shame on you.
Filter:good.
Pipe: waste of $.
"Moon"
Filter:good.
Pipe: waste of $.
"Moon"
Filter:good.
Pipe: waste of $.
"Moon"
Filter:good.
Pipe: waste of $.
"Moon"
the fact that the SS has a pretty good system keeps it from gaining much. My GTP is horrible and it will gain 17 HP.
I can't say the same with other MFG I have to deal with.
I have put K&N filters or filters and intakes on everything I have owned Including diesels, the SS is the 1st vehicle that I have not put one on yet as I just don't see the proof that there are gains. The reason is that the SS intake is VERY well designed and has very little restriction. Hard to improve on.... Also, usually adding a K&N intake will improve the looks of the engine compartment. On this system, it is my humble opinion that this is not the case.....
It would be nice if any of our members with an SS AND the K&N intake could give some objective feedback and some pics.....
Also, as Hyper said, over oiling has caused a LOT of problems!
Looking a the pic. of the CAI package, I was under the impression that the pipe they sell you with the kit, is the turbo to I.C.pipe, and that is under pressure. I could be wrong. "Moon"
As far as dressing the engine up, It is just black plastic. So asthetically it is not much of an improvement. I used a K&N filter on my Cadillac and had zero problems. I was thinking about the intake. Now I agree that The performance division did a phenomonal job, but I like options. Does anyone know of any quality intakes out there?
Hey ya'll, I hope everyone is well. I am curious about the K+N intake system that is offered for our Super Sports. It says a 10 HP boost, which isn't bad for the easy upgrade. I am also wondering if GM could tell if I had, had it on at any point. Thanks for the help.
