Wheels for snow tires?
Old Feb 27, 2014 | 09:22 PM
Originally Posted by LawDog88
^^^ Steelies will fit yes. BUT it should be noted that if your car came stock with 18's and you throw 16's on YOUR SPEEDOMETER WILL BE INCORRECT.
Not necessarily - the speedo reading is dependant on the diameter/circumference of the TIRE. It has no relationship to the rim size.
Old Feb 27, 2014 | 09:50 PM
Not true. It will depend on the size of the tire you use. Throw on 16's with a tire the same heighth as the 18's and the speedo will be the same.
Old Feb 28, 2014 | 06:13 AM
finnhhr's Avatar
i have 205/55/16 on similar regular steel wheels during winter as someone posted earlier. ugly as hell, but reason is that is currently cheapest tire size over here and it does not throw so much in speed.speedo off just one mile or two.
hhr has same lug pattern as in cobalt, and here in europe it was easiest to find Opel steel wheels.
Old Apr 6, 2014 | 09:14 PM
GVS's Avatar
GVS
For the record, the Borbet LV5 17" wheel is one of the few 17s which clear the front Brembo brakes. I have these as my winter set just in case I upgrade to Brembos in the future.
dbking2446
North East
Oct 28, 2008 10:16 PM
