Winter Wheels + TPMS
Old Nov 20, 2008 | 06:46 AM
Raysupe's Avatar
Question Winter Wheels + TPMS
I want to purchase new 16" steelies and snows from tirerack, does anyone know of any problems that may occure if I do not have the TPMS installed on the wheels I was thinking that the warning lite would stay on.
Old Nov 20, 2008 | 08:24 AM
damienSS's Avatar
warning light comes on, message indicates 'service TPMS' and it beeps for a few seconds when you start the vehicle. Nothing else happens other then the email you get from onstar's monthly diagnostic report.
Old Nov 20, 2008 | 11:27 AM
hyperv6's Avatar
I just put The TPMS on my wheels and kept the system going. You can get the rubber stem monitors GM now uses that let youy replace the stem if needed.
Old Nov 20, 2008 | 11:43 AM
traketo's Avatar
Do you have a part # and where to get them at a reasonable price?
Old Nov 21, 2008 | 07:53 PM
Raysupe's Avatar
I will Probably get the sensors and go with these
16X6.5 New Steel Wheel Black Painted
for 2008 Chevrolet HHR SS
205/60R16 Bridgestone Blizzak WS-60 Blackwall
315MHZ TIRE PRESSURE SENSOR
Old Nov 21, 2008 | 08:49 PM
Cokeybill's Avatar
I did the same except I went with 215/60R/16s.
Old Nov 21, 2008 | 08:53 PM
Rcflyboy's Avatar
Here is a set for $50 on ebay/
Item number: 370112968445
Old Nov 21, 2008 | 08:59 PM
Raysupe's Avatar
Don"t know much about tires, whats the difference?
Old Nov 21, 2008 | 09:22 PM
Cokeybill's Avatar
click below. Put in your oem tire and rim, then your winter tire and rim in the next column. Use +42 offset. scroll down and read the specs. then try with the oem and my 215/60R/16s. speed etc.
http://www.rims-n-tires.com/rt_specs.jsp
Old Nov 22, 2008 | 07:58 AM
hyperv6's Avatar
I will have to see if I can find the part#. I will post it when I do. I saved it somewhere.
THe price I paid was cost since I had a connection. It was $31 each. Most places retail them for $49-55 dollars. Shop around and see if anyone will deal with you.
