are your GM chicklets level?
Old Apr 7, 2008 | 09:15 PM
courthousedeb's Avatar
Originally Posted by SSROADSTER
yes it is the GM emblems on the side door, and mine are off slightly, what can I say?????
courthousedeb, where did you get the Nascar emblems? I like those..........
I got them on eBay. Here's an auction from the same guy. Certainly go well with my NASCAR theme I've got going on. Get lots of compliments on them and they certainly look much nicer than the stock "chicklets"
Old Apr 7, 2008 | 09:44 PM
c2vette's Avatar
OK, my chicklets are level, but my SS on the passenger side is raked a full bubble. (I can't believe you actually got me to measure that)...but this stuff is important!
Old Apr 7, 2008 | 09:56 PM
SSROADSTER's Avatar
you are my kind of guy, we think the same, wait until you see the other questioins I ask!!!
Old Apr 7, 2008 | 09:57 PM
SSROADSTER's Avatar
thanks for the info will check out
Old Apr 7, 2008 | 09:58 PM
SSROADSTER's Avatar
Originally Posted by Big Kahuna
I removed mine also...
If you don't think they are level and want to correct that, simply take a hairdryer and heat them up a bit. They come off preety easy when heated up. You can simply re-stick them level or add a bit of 3M tape if you have trouble re-sticking them.
But I warn you, if you remove they, you may like the look and just keep them off like many others have...
I have thought about it, will sleep on it tonight and makeva decision whenever..........
Old Apr 7, 2008 | 10:01 PM
pg318's Avatar
Took notice of the GM chicklets on the SS, even put a level on the top, and they are off ever so slightly, I know I am being anal, but has anyone taken notice of theirs?........................................... ..........Tom
I think the official name for them is the "mark of excellence", so it really should be the one thing that's right. Maybe it's your HHR that's skew.
Old Apr 7, 2008 | 10:17 PM
SSROADSTER's Avatar
So you mean that the chiclet was put on straight and the HHR is slanted????
Don't tell me that, I will be up all night!!!!!!!!!!!!!!!!
Old Apr 8, 2008 | 01:11 AM
Cokeybill's Avatar
The chicklets are suppose to be installed at the plant with a device to make sure that they are level. It seems that the employee in the plant that installs them is short cutting his job operation. This a supervisory problem at the plant that builds your vehicle. He should be making sure that the employee is using the proper equipment to install the chicklets instead of "freehanding" the procedure. I have seen it done firsthand in the Oshawa plant as well. Even the employees on final inspection should have noticed this in the plant before the vehicle rolled off the line!
Old Apr 8, 2008 | 09:41 AM
GTOMIKE's Avatar
I don`t think the chicklet installer in Mexico really cares.
Old Apr 8, 2008 | 09:45 AM
ChevyMgr's Avatar
That would be the polluelo installer then.
