ZZP downpipe first mod?
Old 10-12-2018, 08:59 AM
Donnybrook's Avatar
Hey everyone, I just bought a 08 HHR SS with a manual and was wondering if you thought the zzp downpipe would be a good first performance upgrade. I am new to the turbo game and don’t know too much about them , so any suggestions would be greatly appreciated. And by the way this is my daily driver.
Donnybrook is offline
Old 10-12-2018, 09:01 AM
Welcome to the site, you have to start somewhere!
Oldblue is offline
Old 10-12-2018, 09:04 AM
I don't have an SS... But I can state ZZP makes top shelf parts.
Greybeard999 is offline
Old 10-12-2018, 09:18 AM
Donnybrook's Avatar
Thank you
Old 10-12-2018, 09:21 AM
Donnybrook's Avatar
It definitely sounds like it, from some of the things I’ve seen
Old 10-12-2018, 12:37 PM
Ohiocruiser's Avatar
Welcome. As a ss owner I would suggest you to decide what power numbers you are trying to reach. Simply installing DP won't give you anything. But if you want to start with anything, 3bar map sensors and hptuner will give you the best results.
Ohiocruiser is offline
Old 10-12-2018, 12:57 PM
Donnybrook's Avatar
Yeah it will be mostly better flow I think and I’m probably gonna get a trifecta tune or something similar. I’m not looking for crazy power right now just a little more. Thanks
Old 10-12-2018, 01:53 PM
Cat Man HHR's Avatar
The Trifecta alone is worth the money well spent. Get the better one and it will help with mods.
Cat Man HHR is offline
Old 10-12-2018, 02:33 PM
Technical Moderator
All of the references to exhaust flow are from old guys hotrodding old big blocks. Believe it or not, there is a science applied by the designers of modern turbo systems. Some even require some back pressure.
My advice is to not monkey with one part of the system without taking the entire system into account. In this day of C.A.F.E. standards; do you think they purposely throttle the exhaust compared to the intake?
just my
donbrew is offline
Old 10-12-2018, 02:42 PM
just my
exactly my point. There's not a lot you can improve on stock engine, if any. So running higher boost with more aggressive timing is the way to go. And that will reduce life of the turbocharger. Unless you wanna go bigger turbocharger...but that is different story.
Quick Reply: ZZP downpipe first mod?
