Backlit Window Buttons
Old Jul 31, 2006 | 11:23 PM
  #31
crazybob's Avatar
276-316. Thanks again, CH. I will be your "LED brother"!
Old Aug 1, 2006 | 07:50 PM
  #32
captain howdy's Avatar
The more the merrier. Everone should swap their LEDs. They are only a couple of bucks plus it only takes a couple of minutes and a pair of wire cutters.
Old Aug 1, 2006 | 10:08 PM
  #33
crazybob's Avatar
Just a quick note for anyone else wanting to do this mod: An LED is polarity sensitive. The flat side of the LED or (if it has a) shorter lead it goes to (-). OR, if you can see inside the LED, the larger of the two electrodes goes to (-).
In the above pic, the top electrode is (+), and the bottom is (-).
It won't light up if you connect it backwards, and you can actually pop an LED sometimes when it is connected backwards.
Old Aug 1, 2006 | 10:11 PM
  #34
Yeah, I should have mentioned that.
Old Aug 1, 2006 | 11:51 PM
  #35
Lee3333's Avatar
I wish I had known about the color option of the LED's. Then, maybe I would not have mounted my map light over the hole. At least I could aim it down to see the power window buttons.
I did install a 12 volt socket which makes for a neater power line for my radar detector.
[IMG][/IMG]
Old Jul 15, 2007 | 03:13 AM
  #36
RiverRatt3's Avatar
Thats really cool. Thanks for the instuctions.
Old Sep 6, 2007 | 09:58 AM
  #37
itschaboykenny's Avatar
Exclamation Backlit Window Buttons
this wouldn't be a backlit for the window buttons but would be a good idea for $14.97 (+ S & H) click the link below:
http://www.urban-neon-car-lights.com...les-p-287.html
Old Apr 20, 2008 | 10:08 AM
  #38
HHorange's Avatar
I have also added the El light string to my window switches, but I have found what I believe to be a better way to power them.
In the pictures of the interior fuse block elsewhere in this thread you will find the red wire connector that goes to the fuse block. Look for the dark gray/brownish wire just under and to the left of the mounting screw. This wire only goes "hot" when the headlights come on. That will give you a switched 12 volt feed whenever the driving/headlights come on. whether you turn the lights on or the headlights are set on auto. No worries about turning the lights on or forgetting to turn them off.
Old Jun 7, 2008 | 11:38 PM
  #39
Cajun's Avatar
2008 Question
Has anyone removed the power window switch cover on a 2008...?
I cannot locate the "slots" mentioned in the 1st post of this thread...
Thanks,
Cajun
Old Jun 8, 2008 | 09:34 AM
  #40
an08HHR's Avatar
Thanks,Cajun
When you remove the black rubber liner you will see two slots on the back of the housing facing the shifter. Insert the screwdriver blade in the slot and push slightly back while lifting up on the cover through the large hole in the bottom, you only lift it 1/8 of an inch or so just to clear the tabs. Once the two tabs are released then you can pull the unit up and out. The first post shows the pic of the fasteners that hold it in place so you can tell from that how is is held.
06-08 should be the same. Mine is an 08 and have removed it just as the first post said to do it
