Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Hey thanks for the information. as you may have guessed, my '06 HHR LT 2.4 autobox is having the hard shifting symptom, but only after hiway rides, and not every time. there are no other driveability issues. the is no CEL lit, or T/C (which I asume means traction control). rading thru I got the idea that this malfunction does not always cause the CEL to illuminate, but that a code will show when accessing the OBD II software. is this true? I have a code scan tool. Oh, BTW, where's the OBD II connector on the HHR?
The solenoids rely on oil to do their thing - meaning they use oil pressure, and also seem to be picky on having clean oil, as they can get contaminated with "crud" (scientific term :-) ).
Generating the code requires a number of instances of the problem determined by the software built into the system. So, you may not find a code generated yet if it is not a hard failure. A code may get generated down the road, so to speak, dependant on the problem getting more severe, or frequent.
There are other problems that can cause the tc light and hard shifting, so one cannot assume it is the actuator solenoids. However, they are definately suspect, until you can get a code generated which will help pinpoint the problem.
Does all that make sense?
If I was you, I'd check the oil level, and top up if necessary, or do an oil and filter change if it has been a while since last done, and see if that resolves the issue.
The OBD plugin port is under the dash, directly under the steering column - which is pretty much the standard location for most vehicles.
thanks, Whopper. I bought this car on 5/13, and the dealer should have changed the oil and filter, or so they'd mentioned. I'll check it today and see. as far as the OBD II connector, thanks, though I've had a couple V-dubs which located them in other places than under the steering column. On both my old MK III Jetta and the ford Focus I had before this the connector was behind a cover on the face of the dash.
I figured rather than hunting around I'd just ask here ;-)
Got the unit out (it was easy thanks to instructions from Whopper) and took it down to Autozone. They don't have it listed in their database. Went across the street to PepBoys - they don't have it either. The guys there said that it was a dealer item. Stopped by the Chevy dealer and they had one on the shelf. ($50). Got it in no problem. No CEL yet.
To add to the solenoid or sensor confusion: the box the unit came in says "valve". I looked over this thing and still don't know how it works. I have a picture; just don't know how to post a pic. The term "valve" indicates something that moves to alter a flow of a fluid... hence the name "solenoid" would seem to be appropriate.
thanks.
thanks.
