Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old 07-22-2013, 09:30 AM
  #341
macarchie's Avatar
My quest started by trying to confirm that the same component (#1265-5420) was used in both the 2.4L and the 2.2L. It is.
For the 2.2L:
intake (1265-5420)
exhaust (1265-5421)
No CEL... problem fixed. Next problem is to convince my wife to let me buy another HHR for our teenage daughter. (She likes my car and wants to take it away from me.)
later, Jimmy
macarchie is offline
Old 07-22-2013, 12:46 PM
  #342
For the 2.2L:
intake (1265-5420)
exhaust (1265-5421)
later, Jimmy
thanks - will update the first posting on this thread to indicate that the 2.2's with VVT do use the same solenoids.
whopper is offline
Old 07-22-2013, 07:14 PM
  #343
I just recently found out why my old 2008 2.2L had no solenoids. No VVT, duh!
donbrew is offline
Old 07-25-2013, 06:47 PM
  #344
Waldo's Avatar
The grommet you might be able to get at your local chevy parts dept - I don't imagine they are much in the way of $'s. Mine broke the last time I took the air cleaner housing off, the same as yours (all dried and cracked). I jury rigged a grommet from my parts bins so it would work -I think it was for holding a motorcycle side cover originally.
I just did the solenoid replacement, and also had the front grommet fall apart on me. GM calls this part an "Insulator". It's part #12563914, and it's current list is $3.47.
Thanks for posting this "how to"!
Waldo is offline
Old 07-26-2013, 01:03 AM
  #345
You are most welcome - and thanks for the info on the part number and price of the grommet/insulator. I;ve updated the first post in the thread to add your info. :)
whopper is offline
Old 07-31-2013, 10:17 AM
  #346
greghub's Avatar
I have an '06 2.4L, and have the check engine light and hard shift traction light on.. Got the code ran today and it came back as P0011 for the intake cam position actuator. Any consensus as to whether I should have both intake and exhaust changed??
greghub is offline
Old 07-31-2013, 10:39 AM
  #347
I changed both of mine when only one was giving an error code - it's not a hard job so either way works. You have to decide for yourself.
whopper is offline
Old 07-31-2013, 09:43 PM
  #348
thenikeman's Avatar
Exclamation
Hi, I didn't want to miss out on the party!
2009 HHR 2.4
Current Fault Log
P0010: "A" Camshaft Position Actuator Circuit (Bank 1)
Is this covered under warranty? If not, just double checking what part(s) I will want to get ordered. The wife hasn't noticed any driving issues, so is it OK to drive until we get it fixed?
Thanks!
thenikeman is offline
Old 07-31-2013, 09:52 PM
  #349
If you still have drivetrain warranty, then it is covered.
The part numbers, and prices, are detailed in the first posting in this thread. If she hasn't noticed the hard shifting............. Shame.
It's sort of ok to drive - I would not want to put a bag of miles on it though, and be gentle with the throttle. It can't be that good for the transmission, nor the engine mounts, or the flex pipe on the exhaust.
It's an easy fix - less than 45 minutes taking your time with it - all detailed in the first post in this thread.
whopper is offline
Old 07-31-2013, 10:06 PM
  #350
thenikeman's Avatar
Thanks for the quick reply, whopper. I just wanted to double check since there have been so many requests / variations. So my best bet would be to replace both solenoids, and use the newest part #'s of: 12655420 and 12655421?
Quick Reply: Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
