Home-Grown CAI
I know. But I am not going to. A DYNO run would cost me more than what I spent to build the intake. Even if it has the exact same power/torque as stock, I choose it over the stock box. It is just so much cleaner looking than the giant plastic box.
Originally Posted by Long_Tall_Texan
This allows cold air to flow through the grill ... then the hot air flows out the rear of the engine compartment where the hood meets the windshield.
Watch your engine temps now. The covers you removed on the sides of the radiator were placed there to cause the electric fan to "draw" more air through the radiator core.
By removing these panels you have actually reduced the amount of cooling air that travels through the rad core.
It's not a good idea to tamper with this (removing air dam panels & weatherstripping) - especially on newer computer-controlled engines.
Engineers spend weeks studying the effects of air flow patterns through an engine compartment.
I've seen a slew of guys do things like this and get worse performance than stock.
Not trying to shoot down your ingenuity
- just a tip,
Thanks for the heads up.
I did think of that though. I have had it like this for over a month now in 110° temps here in TX with no problems. I have kept an eye on the engine temp and it is staying right where it should. Anyway, it works for me, but everyone should keep that in mind with any mods they do...
