How to install drop Springs...
Old Mar 16, 2007 | 01:09 PM
buz1953's Avatar
Great step by step on this! I'l do it on my 1st weekend home!!!!
Old Mar 30, 2008 | 02:18 PM
xzombiex66's Avatar
One question do i have to remove any brake lines from the rear or front when lowering my HHR?
Old Mar 30, 2008 | 06:14 PM
frenchie's Avatar
What are the largest wheel/tire combo that will fit, after it is lowered? It looks realclose in the rear of the back wheel well? Steve
Old Mar 30, 2008 | 06:30 PM
Lee3333's Avatar
I just did the rear leveling springs, and you do not have to disconnect the brake lines. But it is recommended that you remove them from the bracket that holds them in place. The extra slack is helpful in preventing them from getting damaged. The fronts are more involved, but the back took less than an hour for both sides.
Once they settle, though, you have to be careful when the car is on a lift or you jack up both sides at once. The springs are so short that they can pop out. You just need to hold them in place when you lower the car.
Old Mar 30, 2008 | 06:33 PM
TkHHR's Avatar
The one step left out here is you DO remove the brake line brackets on the rear from thier mounts just to allow plenty of length for the brake lines while the axel drops out of the way. I believe it was a 10mm bolt to remove the brackets. After the spring is installed you bolt them back on. Simple but important step.
Old Oct 7, 2012 | 01:05 PM
skyline26's Avatar
old thread..but why is it recommended that you cut the bump stop?
Old Oct 7, 2012 | 01:11 PM
So it don't go thunk, over a speed bump, if you can still clear one.
Old Oct 8, 2012 | 07:42 AM
kwe45919's Avatar
It keeps you from "bottoming" out early during travel of the suspension. It just gives you an extra inch of travel for being lower.
Old May 12, 2013 | 12:22 PM
brossow's Avatar
I know this is an old thread, but just wanted to say THANK YOU for posting this! It helped me to finally get my rear Goldlines installed. (Winter wheel removal turned into a rear brake job, which then turned into a spring installation.)
Old May 12, 2013 | 02:19 PM
And post up a picture to show us your cars new "stance".
