How-to install upgraded timing chain guide bolt
I am looking at the picture of the OE bolt you show removed. Small Threads on the end only?
New bolt …Large threads and No threads on the end?
2 different configurations?
Same question
Also … Is this bolt shown for the 2.2L and 2.4L engine only or will it fit the 2.0L SS ?
Silverfox
Same question
Silverfox
These bolts are common with all three engines, the shank on the end fits into the front guide upper bolt location, but it doesn’t have threads nor does it go into the threaded hole inside the engine, it is secured by the threads in that outside part , see post #3
https://www.chevyhhr.net/forums/main...il-wear-59951/
Same question
Silverfox
Same question
Silverfox
The replacement doesn't have any.
The smaller part of the "stud" fits into where the threads are in the block to support the new part.
Otherwise the bolt has no real support.
