HOW TO: Rear Disc Brakes
Old Oct 13, 2013 | 06:11 PM
badassbowtie's Avatar
For those of you equipped with rear disc brakes, here is a "how to" change them out as they are a little different from the front disc brakes.
You will need:
Jack
Jack stand(s)
Lug wrench
Ratchet
Extension
14mm socket
18mm socket
Flat tip screw driver
Channel locks
My car has about 65,500 miles on it, So they did go a bit early, but I don't have the best driving habits...
1)Park the car on a level surface. Loosen the lug nuts, and jack up the side of the car right near the rear tire. I usually jack up the car by the pinch weld, but you can also place the jack under the spot where the suspension mounts to the under-body
2) Place jack stand and remove tire. You should see this (Possibly without the red)
3) Remove the caliper by removing the two caliper bolts(14mm). Use the channel locks to hold the sliders from rotating.
4)Remove the old brake pads. You may need the flat tip screw driver to pry them out. Old vs New. I was way overdue
5)Remove the caliper mounting bracket by removing the two mounting bolts (18mm)
6)Pull the old rotor off. It is a floating rotor so it should come off with a little elbow grease or weapon of your choice.
7)Clean the new rotor with parts cleaner to remove the greasy film from the manufacturer. Then place the new rotor on the hub. If your hub is rusty enough, you may want to use a wire brush and remove most of the rust on the hub, before putting the new rotor on it.
8)Put the caliper mounting bracket back on. You may also want to clean and remove excess rust from this too.
9)Put the new pads on. Should look something like this(I didn't replace my rotors):
10)This is the part that's different form the front brakes. The caliper piston DOES NOT get forced back in. You must rotate it clockwise, back into the caliper. This is where the channel locks came in handy. When turning, be careful not to grab the rubber boot with the channel locks
11)Make sure your caliper sliders are still functioning, and put the caliper back on...Caliper bolts(or pins) are NOT supposed to be super tight. 30 ftlbs or so.
12)Put you tire back on, and lower the car. Pump your brake pedal until it stiffens up. Also you may have to re-tension the E-brake. Pull up on it a few times to check the tension.
13)Have a beer(If you are of age of course)
If you notice one side of your cars brakes are worn more than the other, than you may have a caliper hanging up, or E- brake hanging up. Also while you have the tire off, you can check other things like struts/shocks etc.
Old Oct 13, 2013 | 06:28 PM
nice pictures and write up Badassbowtie , looks like you just did this in time, with those thin pads.
Old Oct 13, 2013 | 07:01 PM
Nice write up.
Glad I don't live up North. Those winter conditions wreck havoc as far as rusting things up.
Old Oct 13, 2013 | 07:17 PM
Nice write up.
I agree with you...I have been thinking about moving...I really like Virginia. I need a few more years of experience in my field of expertise (appliance service tech) and then I'm gone(hopefully).
Old Oct 17, 2013 | 08:50 PM
frdfandc's Avatar
Instead of using Channel loc pliers, this tool will make things a little easier.
Old Feb 28, 2019 | 02:15 PM
fanbelt.1's Avatar
Great how-to! Do you recommend lubing the sliders during reassembly?
Old Feb 28, 2019 | 02:51 PM
Cat Man HHR's Avatar
Yes. Use a silicone grease if you have it.
Radco
Mar 29, 2013 12:17 PM
peter muina
18
Mar 16, 2010 10:19 PM
Hotrodbob
25
Sep 18, 2007 08:55 AM
jeffs396
May 23, 2007 07:19 PM
PDX HHR
10
May 12, 2006 10:13 AM
