Inside door handle replace
Old Mar 10, 2012 | 09:35 PM
oneton's Avatar
Found this clip for replacing inside door handle
http://www.youtube.com/watch?v=BWT7m2y4KcU
Old Mar 10, 2012 | 09:38 PM
Cool! Already did one Dorman kit on the '06 because my lovely wife couldn't break her habit of using the chrome handle to pull the door closed....I think my grumbling and swearing in both French and English gave her the idea not to do that anymore.
Old Mar 10, 2012 | 10:54 PM
oneton's Avatar
My wife did her driver door by keep pulling when door is locked. On a 5 speed you have to unlock doors if eng. is running. She would stop to get paper & mail at end of lane, Pull E break and try to open door time after time till it said no more.
Old Mar 11, 2012 | 03:02 PM
hyperv6's Avatar
It always amazes me how they give you a door pull and people use the handel.
Old Apr 3, 2013 | 10:25 AM
pduffey's Avatar
I wondered - in a different thread - if the GM kit they give you is different than the Dorman product.
Old Apr 3, 2013 | 06:23 PM
Sno White's Avatar
Here is "pduffey"'s post from that thread:
I need to replace a broken interior door handle. GM has a kit, but so does "Dorman." Has anyone had experience with these kits, enough to tell me that they're not quite the same as far as what each kit contains? Dorman seems to have a drill bit. Does the GM kit have the same bit included?
Thank you.
I wasn’t aware GM had come out with their own kit – if that is confirmed, I would forgo all the drilling and just remove the hinge pin and replace the broken chrome plated plastic door handle with the one from the GM kit.
Same inquiry for the Dorman handle kit – is it compatible with the stock GM hardware? Why do all the work of drilling, gluing and screwing when you may not have to!
I know the hinge pin can be removed as I did it to sand off the chrome and repaint in a non-reflective color.
Old Apr 9, 2013 | 04:29 PM
Sno White's Avatar
Well there does seem to be a handle only replacement see:
https://www.chevyhhr.net/forums/show...ht=door+handle
Mine just broke and I wasn't using it as a closing handle - I was opening the door.
Old May 11, 2013 | 10:10 PM
REDSEDANDELIVERY's Avatar
My door handle broke this evening, can't believe the junk parts on a great little car..
How sad, shame on gm for using junk ...
Old Jan 23, 2014 | 04:59 PM
rainmanva's Avatar
Thumbs down
mine broke as well, ordered the part on amazon.com for 47.50 and today price jumped up to $61.35
crazy crazy crazy! 47.50 for cheap, plastic parts. love my car but hate buying the parts!! RIP OFF!
Old Jan 23, 2014 | 05:20 PM
Since it will come up inevitably, I'll ask in the nicest way possible with no offense intended.
You do know the chrome handle is just for opening the doors, not pulling them closed?
That's the job of the molded grip in the door panel, pulling the doors closed repeatedly with the chrome loop handle will break them eventually.
And they're really fragile in cold weather.
