Install Trailer Hitch- Part 2
Old Dec 13, 2010 | 09:31 AM
bilko's Avatar
Originally Posted by HHRNole
Nice post on putting on hitch. I put mine on after being told that my new HHR didn't come with cross rails for the side rails($350 for the cross rails) I had a car top carrier that I was going to put on,but I got another idea. Why not put on a hitch and build a trailer using my carrier. Found a small trailer kit at Harbor Freight tools that matched the size of my carrier
That looks GREAT!
By the way, What are the wheels you have, and can you post a close up?
I'm looking for a set , and I like the way your wheels look.
Old Dec 13, 2010 | 10:14 AM
HHR_style's Avatar
First run with my new trailer!
As promised, here's a couple shots of my first run with my new trailer.
I went to the motocross track in Blacksburg, SC. Here I am loaded up for the trip home:
Here's my pit area after my first ride. The track was a bit muddy in spots:
Track pic:
Overall impressions of driving with a trailer. Luckily I did not have to back up anywhere. I'm sure that would've been interesting. I've got to get out to an empty parking lot & practice!
You can feel the trailer when you go over bumpy roads. It kind of jerks & bounces along the roadway. The tounge fits quite loosely in the reciever. This slop was quite annoying as the weight of the trailer magnifies this movement to where it's banging everything side to side & up & down. I needed to find a shim of some kind to get rid of the sloppyness. I started layering strips of duct tape on each side of the tounge until it fit a bit tighter than before. It's not perfect but it's better than before.
Overall the trailer was a dream come true. I made it to the track & back without a problem & look forward to many more trailer trips in the future!
Old Dec 14, 2010 | 12:02 AM
Very Cool... might try some thin galvanized metal to cut for shims..
The shorter the trailer, the tougher to 'catch it' when backing up..
Lil practice you'll be great at it..
PS: Nice touch adding the running boards too..
Old Dec 14, 2010 | 05:23 AM
BlackknighT's Avatar
Check to see if the tongue collar is adjustable-most are. The locking lever gets removed and then the inside collar piece has an adjustment to bring it tighter against the ball. Also check you are using the right ball. Most light weight trailers use 1 7/8 while ones alittle heavier in the 300lb to 350lb range are 2 inch.
Old Dec 15, 2010 | 09:36 PM
HHRNole's Avatar
Originally Posted by bilko
That looks GREAT!
Voxx Monza from Discount tire,used my stock center caps instead of Voxx caps.Caps sit inside hub,glued in with clear silicone.
Old Dec 16, 2010 | 12:43 PM
HHR_style's Avatar
My tongue collar is not adjustable. It's just an open tube all the way back. P.S. The ball is correct.
Old Dec 16, 2010 | 09:49 PM
When you get a moment check out the video. You'll see what I am talking about.
http://www.ehow.com/video_2326713_ma...s-coupler.html
Old Dec 17, 2010 | 08:07 AM
larry95b's Avatar
Good video here of an install on an hhr, it helped me see what I was getting into before I bought the hitch. Also they sell these great t harnesses for the lights it just plugs into where the harness goes and it has a new lead you plug the bulb into no cutting, splicing or trying to figure out what wire is what. Hope this helps. they also have the vid for the harness as well.
http://www.etrailer.com/tv-hitch_ins...chevy_hhr.aspx
Old Dec 17, 2010 | 08:08 AM
HHR_style's Avatar
Ball to coupler good!
Thanks for the video. Thats a good site for me!
The ball to coupler connection is fine. Nice & tight. The looseness is with the tounge & the reciever tube. I'll be looking for some thin sheet metal as suggested by sleeper.
Here's the ball I had to buy to fit the Curt Hitch:
Old Dec 17, 2010 | 12:51 PM
HHR_style's Avatar
Ball Mount bar shimming
Here is a pic of the ball mount. You can see where I added strips of duct tape in an attempt to minimize the slop. The current placement of the tape enables the ball mount bar to still slide into the reciever. It's still a bit loose but any more tape & it wont slide in at all:
Here is the top view of the installed ball with warning labels:
