Keyfob cold solder repair
Old Jan 21, 2013 | 05:08 PM
  #61
Originally Posted by steven2063
i soldered mine and only the horn alarm works now, do the rubber buttons contacts need to be cleaned with something?
Yes, use a pencil eraser and rubbing alcohol. If the contacts on the rubber are worn out, you can get a replacement case that includes the pad on Ebay for around $10 or the keyless fix thing that is referenced in this thread.
Old Jan 27, 2013 | 11:19 AM
  #62
SmootHHR's Avatar
I took all of your collective advice and fixed my dead remote! Works like a champ. Cleaned the back of the pads with alcohol and glued some foil in. Went to do it to my "good" remote and found that it had a broken battery clip solder. Went ahead and foiled the pads on that one too, but will get it soldered this week.
Thanks for the advice!
Old Mar 15, 2013 | 10:27 PM
  #63
sabrajet's Avatar
Foil works
My remote stopped working about 1 year ago and I just did not want to pay the dealer or anyone else $250 (part and programming). Just read a post on using tin foil--so I did.
Tore offf a couple of small pieces placed in the pad socket and bam! My remote is now working fine! Thanks for the tip! Didn't use exacto knife or glue like suggested and got the same results!
This website is aswsome--wish I could find the post I saw so I could think the person who gave this info--but you know who you are and I thank you very much!!!
Old May 6, 2013 | 12:17 PM
  #64
rv4fun's Avatar
Another satisfied customer! I couldn't figure out why one of my remotes suddenly quit working. I tried a new battery and still nothing. Then I figured it needed to be reprogrammed so I began searching for the way to do that. That's when I found out you can't reprogram them without a special scan tool - bummer. Then I ran across this fix! When I reopened the fob, the center tab was still holding but the side arms where raised-up. Before I read this whole post, I just put a drop of solder on the tabs and the remote works again. After reading all the responses and additional instructions, I see I'll need to redo my work to add a couple of fine wires to ensure the side arms stay down.
A big THANK YOU! to all who posted this fix!
Old May 6, 2013 | 01:11 PM
  #65
southerncomfort's Avatar
Fyi...the key pads for them are available on line....about 6 or 7 dollars...cheaper then buying a whole new one 100 plus....s c
Old May 6, 2013 | 01:47 PM
  #66
solman98's Avatar
Thanks for the reminder on this. Mine didn't work at one time this past weekend. Just checked and 2 of the 3 solder joints are broken. Will fix this tonight.
Old Jul 25, 2013 | 09:57 AM
  #67
TX-2LT's Avatar
My first attempt at soldering was a success.
Now I am staring at the stack of dead computer mother boards in my house.
Old Jul 25, 2013 | 06:23 PM
  #68
Would you pay shipping for some of mine?
Old Jul 28, 2013 | 10:21 AM
  #69
finnhhr's Avatar
this is great fix; i just thoght well nothing helps, and my key fobs LOOK good so doubted all fixes...
add just foils on below locking and unlocking buttons: WORKS LIKE DREAM!
i even didnt clean them or glued the foil, just layed the foil there.
THANKS FOR WHO EVER INVENTED THIS FIX!!!
Old Jul 29, 2013 | 07:18 PM
  #70
gerrbear's Avatar
broken fob
found the same and soldered it in no time all is well
