Replacing Lower Control Arms
Old Jan 7, 2021 | 04:36 PM
  #161
Bonez's Avatar
Originally Posted by russkaine
that screw has a angle on the tip thats normal.
Yep made that way, new ones are the same , replaced mine not too long ago.
Old Jan 7, 2021 | 04:39 PM
  #162
Bonez's Avatar
Originally Posted by Oldblue
I pulled the LCA’s out, and the ball socket is loose in the Moog bushings , however , they have been subjected to pot holes and rough train tracks and broken pavement over 3 years and 125,000 klms.
I’ve stepped up to the zinc coated Moog K201285 bearing bushings.
The worn parts allowed the LCA’s to contact the top and bottom of the pocket they fit into in the unibody.
Here is the bottom, the centre bolt sleeve is loose and you can see the mark on the LCA above the grass blades on the right.
This is the top side, the bushing is pressed up and out, the new bushing presses in from this side, it has a taper or bevel to start it into the LCA, the hole has a slight bevel also to start the bushing in, I used a 1 7/8 socket and 8lb hammer to drive them home, using an old brake disc for an anvil.
Oldblue , have you cut one of those old MOOGs open? I was looking at the design as I wondered what made them better.... apparently that sleeve has a ball like hump in the middle of it so it stays solid in the rubber ( wont slide out like the normal steel sleeve. Just wondered if you actually seen that or not, or any pictures?
Old Jan 7, 2021 | 06:10 PM
  #163
No, I pressed out the old Moog problem solver, and pressed in the new Moog replacement problem solvers, then sent the worn ones back to get a full warranty refund.
I found this
Old Sep 12, 2024 | 12:37 PM
  #164
Take you angle grinder and grind these rivets on the ball joint side flat. Then centre punch them and drill 1/8 hole straight down they them , then 1/4 then 5/16. Drill the heads off with a 1/2 drill bit just until the head pops off Knock the ball joint off the lac and then drive the remaining part of the rivet out of the LCA.
Install the bolts provided in the ball joint package (these are Moogs) and torque to 50 ft lbs .
Old Sep 12, 2024 | 03:59 PM
  #165
PulpFriction's Avatar
No, I pressed out the old Moog problem solver, and pressed in the new Moog replacement problem solvers, ...
So is this the correct item?
Old Sep 13, 2024 | 09:01 AM
  #166
K201285 Moog rear bushing replacement, yes
Old Mar 10, 2025 | 09:41 PM
  #167
tooter1's Avatar
I have an '07 LT and will probably be replacing the front LCA's and don't know if they have been replaced before I bought the car a couple years ago but, I looked at them through the fender area and it has aluminum arms on it now.
I have the FE1 suspension and thought all the FE1 arms were steel, am I wrong on the steel?
Old Mar 10, 2025 | 09:50 PM
  #168
Yes. All HHR’s came from the factory with aluminum LCA’s.
FE1, FE3 and the FE5’s were all aluminum.
Old Mar 10, 2025 | 10:00 PM
  #169
tooter1's Avatar
WOW, good to know.
Detroit Axle has some steel ones that say for FE1, wonder if they would work?
Old Mar 11, 2025 | 06:37 AM
  #170
No the pressed steel control arms are for a lighter car , just press the Moog K201285 bushings into your aluminum LCA’s
