Replacing the Oil Pressure Sending Unit
Old Dec 14, 2018 | 07:02 PM
  #31
Jay23's Avatar
what does it mean "1/4 pipe thread"?
I understand in standard international metric system. I remember all those stupid sizes in wrenches like 1/2 it's 12.54mm, 3/8 it's close to 10mm etc.
I'm not sure will I find it(sensor) tomorrow because I will walk to the junk yard and especially -- it's Saturday.
Also one more question about torque starter bolts - is it really just 16-18 lbs? I want to add blue thread locker - is it a good idea?
Old Dec 14, 2018 | 09:28 PM
  #32
ap This Size Pipe:
Use This Drill Bit:
(Closest Fractional:)
Decimal Inches:
1/8-27 NPT
Ltr.R
.3390
1/4-18 NPT
7/16"
7/16"
.4375
3/8-18 NPT
37/64"
Grab an a used oil pressure sensor, as for the bolts yes, and use the blue loctite
Old Dec 15, 2018 | 09:38 AM
  #33
06REDSEDANDELIVERY's Avatar
Mine was dripping from where the plastic meets the metal. I have had this type of unit fail on other cars as well.
On my 85 it failed when the metal corroded and the plastic blew out - what a mess....
Old Dec 15, 2018 | 03:32 PM
  #34
Cat Man HHR's Avatar
https://mdmetric.com/tech/metnptcomp.htm
Old Dec 15, 2018 | 07:34 PM
  #35
- oil pressure switch - 16 lb ft
- anti-knock sensor - 18 lb ft
- reattach the connector for the anti-knock sensor, and push the red tab in to lock it in position
- install the starter with the two bolts (14mm socket) - 39 lb ft
Old Dec 16, 2018 | 06:13 PM
  #36
Jay23's Avatar
didn't use torque wrench. Starter has 15mm bolts.
Took out an old oil sensor - there was oil inside connector .
Installed used sensor from 2011 HHR
Old Dec 16, 2018 | 06:15 PM
  #37
And does it now start?
Old Dec 16, 2018 | 06:40 PM
  #38
Jay23's Avatar
yes, why it shouldn't?
Old Dec 16, 2018 | 07:07 PM
  #39
You didn’t clarify in your post, glad to see you got it fixed.
Old Feb 15, 2019 | 01:30 AM
  #40
mrmarkuSS's Avatar
Here is the pic you were all waiting for!
