Stock Radio Removal Guide
OK I ran into a problem.I found the acc wire but its only hot after it runs through the radio.Meaning with the harness unplugged it has no power.I hooked up my remote wire for my amp but the power goes on and off when you open the doors.Even with the keys out of the ignition.Can anyone help?
I haven't messed with the harness yet but new GM's don't have an accessory behind the radio. (GM data module)
You can do what I did for my accessory for my computer, tap into the ignition harness for accessory-
It's the brown wire at the ign. harness
Originally Posted by SoCalHHR
I have a little better schematic than that (if you want it).
Mine is much easier to read.
I actually designed my schematics and they are easy for the "layman" to read and understand.
You are taught that stuff starting in elementary school going all the way up through high school.
