Sunroof quick fix (for those without warranty coverage)
Old Nov 28, 2012 | 07:00 PM
  #61
lafinests213's Avatar
I just want to say thanks for all the info about the sun roof I bouts the supplies and did it my self and got it working again great money saver compered to the dealer only one question were do you put the silicon on the bottom side of the bracket or just on the rivet points?
Old Jan 2, 2013 | 05:33 PM
  #62
MrRiceGuyRJ's Avatar
Originally Posted by GOLFHHR
There is an easy fix to replace the broken mechanism bracket. You don't need to remove the headliner as the TSB recommends. Just drill out the rivets holding the broken bracket from the top, be carful to use the proper size drill as you will need to pop rivet the new bracket back on the rail. Put some silicone on the new bracket to seal for water leaks. You will need a "long nose" rivet tool to be able to pop rivet the new bracket back on. It took me about 30 minutes to complete the job and less than $10 for the bracket. Good luck !
I'd like to see a write up on this fix. Do you have pics? Because the TSB looked so intimidating I was going to do what many did and just remove it all together. If I can "fix" it without removing my headliner, I'd like more detailed instructions on it.
Old May 11, 2013 | 10:41 AM
  #63
REDSEDANDELIVERY's Avatar
Mine broke today on the expressway, the arm had a broken link so it can't be snapped back in. The Passenger (LH) bracket broke as I was closing the sunroof, then the wind broke the arm, pin on the other side. I almost never use the sun roof in the open position, only the rear lift up. Today traffic stopped and it was a great day.. o well.
I had the thermostat problem, the head light fogged and the shifter cable - can't get the key out problems. It's a 2006,2.4, 2LT, crome, running boards, 17's loaded. and I switched to drilled slotted rotors and ceramic pads - last year, no more break issues. The dash compartment latch broke, I used button head screws and fixed it. I also have the front end knock, it's electrical -it goes away when I turn up the radio...
tODAY 5 - 12 THE DOOR HANDLE BROKE. ANOTHER JUNK PART.. HOW SAD
I really like the car, my other cars are classics and actually are made better, shame on Chevy for not addressing the stupid things, .
Based on other cars that my kids have and friends have - including Honda, Lexus and BMW, I've had less problems..
Old May 15, 2013 | 11:10 PM
  #64
cornwalis's Avatar
Sorry to hear about yer probs ive had mine since 06 bought it with 5k on it yes my sun roof clup brke few years ago. And yes dore handles do brake off the doors inner panel. Thwir was an issue with them ive had 2 dores done as a cutesy by gm. But doorman makes the rwplacement handles and its easy to fix it comes in a kit and their instructions online to do it but hit up gm first and try get it done under goodwill. Sway bar links get moog and as for those dam pucks on the lowet controll are do not replace the hole arm thwirs an upgraded ruber puck you canal press in and put a moog ball jont on and problem solved. As for yer brake ive had no prob since I bought the car from my parent. I use ac delco pads and rotors. And thwy last me 3. To 4 years with no vibrations. Lol. But I do them my slf so I no their done right. Infact I do all my work on her dont trust mechanics
Old Jun 5, 2013 | 09:20 PM
  #65
Danny Riley's Avatar
I want to thank you for the instrucktion to fix My sun roof
The fix worked GREAT
Old Jul 2, 2013 | 04:18 AM
  #66
rb.ctr.vance's Avatar
Originally Posted by hhrjeff
HELP! Mine just broke today so I removed the entire windscreen unit. Now the roof will not close all the way. It stops when it gets within 1" of closing. If I then push the other switch on the right, it closes all the way but the rear of the glass is below the level of the roof. If I then push the right switch the other way, it opens 1" again.
It rains a lot in Florida. How do I get the roof to close all the way???????
Did you ever get a reply or fix for this problem? Mine is doing the very some thing. I really appreciate to know how to just get the sunroof to close completly and never open it again. Thanks for any help.
Old Jul 8, 2013 | 08:57 PM
  #67
08ShadowHHR's Avatar
Mine broke a month ago. I told my wife that I would try taking the windscreen out and put a black aftermarket stick on part in place of it. Looks like I was on to something. I thought I would check here first. Now I have to decide whether to replace the rail or do the quick fix. Mine is an 08 with rivets.
Old Jul 14, 2013 | 07:40 AM
  #68
jaytheredneck1's Avatar
2 weeks ago I decided to just take out the deflector. car looks sleek now, and if I go above 70kmh I just hit the vent switch to save my headliner. Problem solved.
Old Jul 22, 2013 | 02:48 PM
  #69
zeta692000's Avatar
what did you install for the wind exactly?
if you don't mind me asking what part did you buy and put on roof to keep wind out?
Old Jul 22, 2013 | 07:08 PM
  #70
jimbob's Avatar
Parts are Cheep
both parts,right and left delivered for $22.00 from gmpartsdirect.com
Part#
*20794829 BRACKET
$3.71
*20794830
$3.78
