Sunroof quick fix (for those without warranty coverage)
Old Jan 28, 2014 | 09:16 PM
  #71
TGP's Avatar
TGP
The hook rivited to the roof holding the windscreen broke. I drilled it out but would like to replace it. Is there anywhere to get just that hook? Bit of a bad design on the HHR there.
Old Aug 25, 2014 | 12:00 PM
  #72
CJ3's Avatar
CJ3
nice job, i just had that issue. i just removed the flex clips and let wind screen lay down. got the plastic deflector. and done in10 min new deflector rocks and is quiter
Old Oct 9, 2014 | 07:59 PM
  #73
jetsaredim's Avatar
Apparently you have to buy the bracket, drill out the rivets and then re-attach with new rivets.
Old Oct 10, 2014 | 10:58 AM
  #74
Beachbum1's Avatar
posted #53 on 6-13-2012 I simply removed the wind screen by removing a couple of screws and purchased a stick on wind deflector from one of the advertisers on this site and it's worked perfectly since. wind deflector cost me about $40.
Update:
As of today my stick on wind deflector has been thru numerous car washes and is still holding up great.It didn't seem worth the expense to get the GM parts.
Old Oct 14, 2014 | 12:51 PM
  #75
Bahbushkah's Avatar
I need a friend or meet a good man that would help fix my hhr... my sunroof did exactly that shown above and also is leaking on my front passenger floor.. it has water droplets that come out of both panels between the front and rear passenger door & the part at the rear door too... it leaks between the piece of panels just below the seatbelts.. I have a roof rack so I dont know how if its that or the sunroof which I dont believe is happening from there... guess it will stay that way because I just dont think I could do it.
Old Oct 14, 2014 | 12:57 PM
  #76
Sorry, try craigs list for ISOs.
Old Oct 14, 2014 | 01:00 PM
  #77
Bahbushkah's Avatar
no thats not an option.
Old Dec 2, 2014 | 06:13 PM
  #78
taz3's Avatar
Thanks to the OP for the info and pics, I ordered the replacement clips for my sunroof, I prefer the cleaner look on the roof, so it is very helpful. Hopefully it will be reasonable for me to replace them myself.
Old Apr 30, 2015 | 09:59 PM
  #79
mtrhead79's Avatar
i ordered my new bracket yesterday and picked it up today. i cant believe the holes are not in the new bracket and that you have to drill them yourself. i will do this next week when the weather will be nicer
Old May 18, 2016 | 08:20 PM
  #80
Coffan's Avatar
This just happemed to me last week, both side ls broke but now my sunroof leaks alittle. It's seems like the glass itself is loose.
