Timing chain kits
Now, here’s a video about a timing chain failure, and the resulting damage
https://youtu.be/K4PHQUuoTmc
There are kits with guides and tensioners , sprockets or no sprockets, it’s up to you to make that decision, I like to replace everything and install a replacement front guide upper bolt!
Please make sure the #1 piston is at top dead centre, and the cam sprockets are aligned properly, prior to removing the tensioner from the timing chain
That video applies to the 2.2 2006 thru 2008,
yes double check those cam sprockets before you install the chain. There’s photos in here somewhere showing how they should be timed .
