bought a used 2009 HHR
Old Oct 10, 2014 | 01:33 PM
ruckdog60's Avatar
It's an LT flex fuel automatic with a 2.4. I've already gotten the ignition and the power steering recalls fixed. Had it for a couple of months. Today I hit a bump and the dash lit up, door locks opened, but the car kept running. Any help with locating where I might look would be appreciated.
Old Oct 10, 2014 | 01:40 PM
LawDog88's Avatar
Fuse boxes are where I might start. Passenger side kick plate under the center, and then the under hood fuse box, drivers' side. Make sure they are all seated, and the under-hood box is firmly planted.
Old Oct 10, 2014 | 01:55 PM
Welcome to the site.
Check the positive cable connection at the underhood fuse box. 2nd place to check, the battery connections in the rear.
Old Oct 10, 2014 | 04:34 PM
ruckdog60's Avatar
bought a used 2009 hhr
Thanks guys. I have checked all the fuses, fuse box and battery connections in the trunk. I found that my 4 way lug wrench had moved around and contacted one of the terminals. I'm hoping that was the problem. I will know when I go out later today. Weird, huh?
Old Oct 10, 2014 | 04:37 PM
More lucky! Secure the lug wrench so this doesn't happen again!
Old Oct 10, 2014 | 05:34 PM
Yep. VERY lucky. It could just as easily fried some electronics and left you
"dead on the spot".
HHR's electrical systems are very sensitive to voltage spikes, up and down. Shorting one out at the battery.....I don't even want to think about that.
Old Oct 10, 2014 | 07:34 PM
LawDog88's Avatar
So, we learned today that we need to keep tools in boxes or wrapped in things. Guess I will have to go check my tool box and make sure it didn't get loose. *not being sarcastic*
Old Nov 16, 2014 | 05:25 AM
cj krause's Avatar
and aboard
Greetings from Texas
pdisme
Jun 18, 2013 04:35 PM
alyce45
Feb 3, 2013 10:03 AM
GDZHHR
Dec 7, 2008 05:23 PM
ZOOMballs
Dec 16, 2007 08:09 PM
MWG2
Dec 15, 2007 08:22 PM
