Introductory from Vegas
We have a HRR 2010, and look forward to getting and giving on the forum.
In N. Las Vegas, but except for 5r yrs in Ajijic MX we located to Las Vegas in 1990 living near UNLV.
(We stepped up to the 10 from a 06 on a good deal)
All I can say today is, if the start locks up, key won't reasonably turn in the lock, especially if you get a warning episode, get the ignition lock changed as it is defective at that point, but if you are under warranty you probably won't be charged a dime.
(And, don't try to fix it with a screwdriver, oils, etc., as you might violate the warranty. But I wonder if it could be tickeled with a
magnet, hmmm)
magnet, hmmm)
WOW. Thanks for that Rowsing Cheer, here's more.
I was thinking tonight of my first HHR oil change and filter, but seems to be either the factory wisdom or my idea is to get conventional oil with up to 15,000 miles range and a oil filter to match and as I am a LOW mile driver now, desert, short trips, retired budget,
keep check but plan to change 1-x a year. I got a $5.oo off coupon on Mobil, so go that way?
to the forum buddypogo!
to the forum
