Engine Heaters
But the problem is, you can't even see any of the block on the rear side, the transmission is mounted there. I think the only way to access it would be to remove either the engine or transmission. Ugh, if I EVER order a brand new car, I'm going to pay the extra $45 and have a block heater installed at the factory!
Eric, to get to the back side of the motor in your Lumina, you can either go undernieth the car and reach up on the back side or you can pull out the front motor mount and take a ratchet strap and pull the top of the motor forward. I have done this before on my 95 Grand Prix when I changed the spark plugs.
For 3.1.
http://www.woodys-auto-supply.com/au...d=ZRO-310-0015
I'll check my sons on thursday and let you know. According to their catalog, they take the same one.
