my OEM 2007 AC Delco battery
Old 09-25-2018, 08:27 PM
IT now sits on my work bench, been in my ride since it was built in 2007, Voltage still tests @ 12.7, & passed my last load test.
I have a new battery in now. But I almost don't want to turn the old one in for the $22 core charge. There's still life in it.
But I know it would konk out one day when I'm away from home or something like that. Guess I've grown attached to it, I would check it most every year, I will miss the 2 screw plugs on the ends to check the acid level tho.
sleeper is offline
Old 09-25-2018, 09:11 PM
I've still got mine...
Greybeard999 is offline
Old 09-25-2018, 09:18 PM
In your ride ?
I think I will get tired of moving it around to make space & go get my $22. core charge refunded sometime soon.
sleeper is offline
Old 09-25-2018, 09:44 PM
Nah... I replaced it a couple of years back. But I don't trade in a good battery as a core.
Old 09-25-2018, 09:46 PM
Makes sense, it's too big for my mower, but a good quick portable source of power.
sleeper is offline
Old 09-26-2018, 11:51 AM
Cat Man HHR's Avatar
Knowing the Amp Hour Rating, load test it to the max and see where your Voltages goes to. As Amps go up, Voltage goes down. This is what happens. If you get 9.6 or 10 Volts the battery is toast. If it doesn't contact Tesla.
Cat Man HHR is offline
Old 09-26-2018, 09:06 PM
It's toast. I did remove the decal a while back, after a post by Donbrew, & I unscrewed all, 6 caps & the sulphation is quite visible, no surprise,
sleeper is offline
Old 09-27-2018, 10:50 AM
Time to recycle that battery, it’s toast!
Oldblue is online now
Old 09-27-2018, 08:21 PM
Blue- I turned it in today, time to move on from that one.
sleeper is offline
Old 09-27-2018, 08:23 PM
Maybe a marker note over the work bench , marking the date
Quick Reply: my OEM 2007 AC Delco battery
