My Big Block 454 Powered Datsun 280z......
Old Aug 29, 2006 | 01:14 AM
cvrogershhr's Avatar
Should be one wild ride.......Keep us updated on your progress, and from experience, easy on the rear end, that torque is really hard on differentials, really.
Old Aug 29, 2006 | 05:49 AM
-md- HHR's Avatar
Smile
A 454 in anything makes me smile.
Old Aug 29, 2006 | 10:12 AM
oldschoolfreak's Avatar
OK Bud, put down the crack pipe and step away from the 454!! LOL i thought i was a speed freak!!??
Old Aug 29, 2006 | 11:52 AM
scaleguy's Avatar
Video !!! We want launch video !!! That is as crazy as my old Big Block Vega, went wicked straight, but didn't turn well !!!
Old Sep 1, 2006 | 02:00 AM
MEAN HHR's Avatar
Talking
Originally Posted by SoCalHHR
And the headers go where?
It looks like the exhaust ports line up perfectly with the strut towers in the fenderwells.
The header tubes are nowhere near the strut towers. Look at the 5th pic in my first post. Directly under the 'R' in Moroso is the header collector. Now look to the right and below of chrome breather on the right hand side, that is the strut tower in the corner of the picture.
The headers are in the pics. The headers fit fine, they had to be modified from the way they were shipped to clear the motor mounts, but everything is fine.
Originally Posted by cvrogershhr
........and from experience, easy on the rear end, that torque is really hard on differentials, really.
Nissan learned from experence and tended to overbuild things as time went on.
If you were breaking diffs, you must of had a 240z or 260z, or a 280z with auto from the factory. Those cars came with R180 rear ends (180mm ring gear) that would break under factory power n/a.
Factory stick 280z's came with the much stronger R200 (200mm ring gear) and I've only seen a handfull of those broken under sub 11 second cars. My 280z is a factory stick car with the R200 open w/3.54 gears. The weak link then becomes the factory U-Joint type axles. Read on....
However, I am swapping out to a 3.69 geared, R230 diff (230mm ring gear or 9 inches) with vLSD (viscous limited slip differental) and CV joints from a '90's Nissan Skyline (Only sold in Japan) and I've never heard of a either a R230 CV or diff breaking, even behind 1000HP twin-turbo'd race engines. The R230 install will take some crafty fabbing and custom Moser axles, but has been done before.
Old Sep 27, 2006 | 11:36 PM
MEAN HHR's Avatar
Talking
Well I go my starter and fired it up today. Ran it for about 10 mins until I noticed my electric temp gauge hadn't moved (Sport-Comp). I didn't want to risk cooking my new motor so I shut it down. Looks like the gauge is junk. So I am prob going to just bite the bullet and just buy another gauge, but mechanical this time.
The motor sounds good, but I won't breathe easier until I have at least 20-30 total cam break-in time.
Anyway, more pictures:
I still need to cleanup all the useless wires:
Old Oct 3, 2006 | 07:06 PM
MEAN HHR's Avatar
Its running now. I had the exhaust installed on Friday afternoon. I've driven it about 50 miles now, including to the local Sonic for Friday night. It drew a small crowd. :bigthumb:
Runs pretty good, still needs alittle carb tuning. However, the carb I have now is only a 650 cfm Double Pumper Holley. Later I'll be stepping up to at least a 800-850.
I haven't rev'd above 3000 yet due to the fact that I didn't install the inter valve springs when I was assembling the heads. I wanted the spring pressure low to make the cam break-in easier. Next weekend I'll prob tear off the valvetrain and swap in the inter valvesprings. After that is taken care of I'll be able to rev the motor freely.
If I had a video camera I would post a vid of the car running for you guys. Honestly its alittle loud for my taste.
Old Aug 22, 2007 | 12:39 AM
MEAN HHR's Avatar
New pics guys....
Traction is still an issue too, my neighbors LOVE me......
That was a 1 second blip in second gear. The tires break loose by 2500 RPM.
Old Aug 22, 2007 | 07:02 AM
CrashMan82's Avatar
Wild!
Old Aug 22, 2007 | 11:41 AM
rebel8ball's Avatar
Originally Posted by MEAN HHR
So, I am anxious to hear what you guys think? Also, if you have any questions, please ask.
ok well i have but one very very important question... can i drive? rofl man that is one seriously fun looking ride, makes me miss my hotrod days...lol
