06 HHR spark Plugs
Old Nov 18, 2013 | 08:31 AM
SteveMaine's Avatar
06 HHR spark plugs
Time to change spark plugs, which ones are best? Thanks
Old Nov 18, 2013 | 08:36 AM
AC Delco's, bar none!! and I have tried several different brands over the last 10 years in my 03 Sunfire GT 2.2 and my 07 HHR 2.2. the AC Delco's are the best IMHO
Old Nov 18, 2013 | 03:20 PM
Snoopy's Avatar
^^^X2^^^^
AC DELCO Iridium at the standard heat range (unless you increased HP by about 100).
Old Nov 18, 2013 | 04:29 PM
skyline26's Avatar
yep yep..like the others said AC Delcos all day every day!!
thread can now be closed haha
Old Nov 18, 2013 | 04:33 PM
not that this hasn't been covered enough already.
Old Oct 3, 2017 | 03:14 PM
SteveMaine's Avatar
06 HHR spark Plugs
What is the best plugs to put in my 06 HHR larger engine. Thanks
Old Oct 3, 2017 | 03:24 PM
41-103 AC Delco iridium,
https://www.summitracing.com/search/...-size/2-4l-145
Do not gap them they come gapped
Do not over tighten them , finger tight then 15ft lbs
Old Oct 3, 2017 | 04:04 PM
Conax's Avatar
A little anti-seize or a smear of oil on the threads is a good idea, too.
Aluminum head, loong threaded part, may tend to bind up.
Cheers!
Old Oct 3, 2017 | 04:15 PM
The General says no to the antiseize on the plugs.
Old Oct 3, 2017 | 04:23 PM
Because Anti-seize encourages over tightening. The plugs are steel, the head is aluminum alloy. If you King Kong the plugs in you can easily pull the threads out of the head.
