06 HHR spark Plugs
Old Feb 16, 2020 | 09:03 PM
X3 AC Delco 41-103 Iridium spark plugs . You risk piston damage from inferior plugs and thread damage to the aluminum cylinder head .
They come per gapped, do not attempt to regap them, the iridium whisker breaks off pretty easily. And the last 100,000 miles.
Old Feb 16, 2020 | 09:17 PM
WendySaree's Avatar
Spark plugs
This is what i used... it says they are pre gapped to .044
https://shop.advanceautoparts.com/p/...338/20650531-P
Old Feb 16, 2020 | 09:37 PM
Get the right plugs...
Old Feb 16, 2020 | 09:42 PM
If you messed with the gap on those plugs that is the problem. Even testing the gap can destroy them.
Old Feb 16, 2020 | 11:23 PM
WendySaree's Avatar
No i didnt mess with the gap thats what they were preset at. But in the owners manual it says they need to be .040 and to use acdelco 41-103 but the specs on those say they are pre gapped .043 i am so confused!
Old Feb 17, 2020 | 02:18 AM
  #26
Cat Man HHR's Avatar
It does get confusing, here is the plug bought ($9.99)
Here is the correct Delco plug ($8.99)
https://shop.advanceautoparts.com/p/...103/15650269-P
Denso says the pre gap is .044"
AC Delco says the pre gap is .043". Measuring a new one out of the box could help with this.
Gap is .001" difference
I have seen running problems when installing different brand plugs.
Could be the case here.
Wonder if there was a problem before changing plugs and thought plugs would fix it.
Old Feb 17, 2020 | 07:36 AM
  #27
I tried those plugs way back , they lasted a week, I learned the hard way. I went back to AC Delco 41-103’s
Old Feb 17, 2020 | 08:59 AM
  #28
WendySaree's Avatar
No pre existing problem. I keep my hhr very well maintenanced due to the fact that i deliver mail in it. I try to make sure its taken care of before issues have the chance to form. Im getting delco plugs now. Thank you all so much.
Old Feb 17, 2020 | 09:44 AM
  #29
We get a discount from RockAuto, if you’re ordering online.
Old Feb 17, 2020 | 10:04 AM
  #30
WendySaree's Avatar
Really?! I did not know that. How do go about getting the discount?
