09 ls panel timing chain tensioner
Can somebody please help me. On a 09 hhr 2.2 can I just replace the timing tensioner or so I have to replace the balance shaft tensioner as well. I've heard different answers. Or do I need to replace other things as well. Just doing some preventative maintenance. Thank you in advance.
Hi Spike,
to the forums!!
Replacing only the tensioner won't do you any good. The entire timing set should be replaced.
Replacing the balance chain set is probably optional, but strongly recommended. The water pump is also in there, and could be replaced.
to the forums!!Replacing only the tensioner won't do you any good. The entire timing set should be replaced.
hurst2001
May 17, 2020 01:55 PM
prod
"How To" Tutorial Library
164
Jul 12, 2018 08:20 PM
Junior864
Oct 12, 2012 02:39 PM
