2010 Chevy HHR LS Trouble lights
Old Aug 25, 2019 | 03:03 PM
Charvel1975's Avatar
Had all trouble lights checked out: ABS, Traction and ESC lights are on dash. Also jerking feeling since the lights have come on. Vehicle was scanned for fault codes, found C0035. Inspected and found wiring loom is cracked and need to start with replacing pigtail harness before replacement of wheel bearing. Driver's side wiper nozzle isn't working, only squirts out of one side. Nozzle clocked and needs replaced. Driver's side headlight: found connector bad and bulb and connector need replaced. Inspected for oil leaks, timing cover gasket leaking. Driver's side interior door handle loose. Also front pads and rotors need replaced.
Old Aug 25, 2019 | 10:11 PM
You have something to do on a Saturday morning. Let us know how you get along.
The oil leak was n the timing cover could just be a loose bolt or the crankshaft seal ,not a hard job .
hhrparts
Jun 14, 2020 09:58 PM
mallomar
Oct 27, 2016 05:48 PM
cgreco
Jun 26, 2016 01:09 PM
Lake Runner
Dec 10, 2012 09:33 AM
14Thumb
Jul 8, 2011 07:05 PM
